Topic: Bulbs inside electronic cluster? (Read 4543 times) previous topic - next topic
Quote from: rizinstar;439467
Is this connector attached to the back of the cluster?
Yes
Because the cluster would not come out enough to unhook anything...I ended up changing the bulbs out from the front of the cluster..
If you have a meter, you can probe the bulb sockets to see if the voltage is there..
I could not even get my hands behind the cluster, was a cable or something holding it.
Yes, the speedometer cable is holding it back.
Digital Fuel Gauge and Speedometer light up on cluster, nothing else.
By this, do you mean LEDs that come on with the ignition switch or the illumination lights that come on with the headlights?
This past summer, I changed these bulbs in my grandson's 97 Taurus. The only thing you could see at night was the gas gauge.
Of the 5 bulbs, only one was actually burned out. The bulbs were just no longer making good contact with the socket due to oxidation of the bulb wires and the sockets.
Speedo cable
