Topic: Ignition TFI module , Hey Dizzy, I DONT FIT YOU ! (Read 5955 times) previous topic - next topic
Great. Once the old time Motorcraft TFI module on mine dies (factory original as far as I can tell) I'll have to find a decent aftermarket one.
So was the TFI failing an issue on all engines relatively equally, or was it most common on the 5.0?
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
the oem units lasted forever,,, I guess.....
they do get hot though
update,
I have a couple oem units lying around, they also have the very same problem, there is a 1/8'' air gap between the TFI and the Dizzy mounting pad.
I have at least a dozen and i am going to check it out. So hang tight for my photos after i research this???
id be interested to see , I can post a pic to ,, thanks!
Quote from: TOM Renzo;438038
And never use a NON PUSH START UNIT!!
Tom,  I'm curious what you mean w/ "non push start" unit.  I've never heard of this,  thanks
OK non push start modules were used on AUTO TRANNYS. They need a higher cranking speed to work. Push start units were for stick cars that could be push started. Reason i never use the Non Push start units is because they need more cranking RPM'S
Interesting. I might have to find a stick or "push start" moduel to play with.
so what car should we use to search for the correct one?
Id guess stick shift mustang.
Any manual shift ford with a TFI.  But i am guessing replacement modules are all consolidated now.
do the number of cylinders matter?
I thought the 4cyl TFI's , 6cly tfi's and 8cyl tfi's are specific to just that.
what do you mean by any stick ford?
Good question, I'd like to know as well. What years interchange for the TFI module, and does 5 speed vs. Auto make a difference?
