Topic: tranny pan leak (Read 1508 times) previous topic - next topic
tranny pan leak
I've replaced the gasket twice still leaking any ideas? 86 aod
any tips would be great
tranny pan leak
If it is a stock pan you have to PEEN down the bolt holes with a BALL PEEN HAMMER. Install a quality gasket not CORK. And torque to specks. If it leaks after that the pump seal might be the issue. Sometimes the pump leaks and it looks like the pan. Also the shifter shaft seal should be checked closely. have a great thursday guys.
tranny pan leak
Good advice Tom. Psst, it's Wednesday still.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
tranny pan leak
Man i loose days all the time. Just a senior moment have a great WEDNESDAY GUYS!!
tranny pan leak
Tom, you have any ideas how many 4l60 pans I see that are leaking because the pans bolt holes are whooped from being over tightened once.......  Great advice you gave him.
Love Foxes, Birds or Stangs.
tranny pan leak
Well thank you for the kind words. You can use a thick bar in your shop vice to make sure the pan is not warped and peen the holes true. The bar in the vice works pretty good. Have a great day guys.
tranny pan leak
Quote from: TOM Renzo;436264
+1
This is why most transmission pans leak. Bent bolt holes.
