Topic: Finished my clutch pedal mod... (Read 10162 times) previous topic - next topic
For me, I have always disliked how close the clutch and brake pedals are. I'm always tapping the edge of the brake pedal when I push the clutch or my feet rub if I am using both pedals, so, I thought about it for a few days and came up with an idea. I bought some small square tubing, and did some cutting and shaping and made a spacer. I then took a second clutch pedestal lever, and cut off what I needed. I removed the clutch pedal lever from the Sport, and went to work. I first drilled the holes I needed through the spacer, and the two clutch pedal levers that all lined up, and kept the actual pedal of the lever at the same height. Once I had the fit right, I removed the lower part of the  Sport's clutch lever, and bolted on the "new" clutch pedal section and spacer. It moved the clutch pedal to the left a little over an inch which actually made a on of difference, and the work I did is all painted black, and hidden by the dash, although if it showed, it wouldn't be noticed. Now that I am happy with the assembly, it will all be tack welded together, although I'm sure the fasteners I used would hold just fine. Pics coming later.
I don't have a problem with the clutch pedal, it's the brake and gas. With my boots on it gets stuck under the brake pedal. Thank god for 2 feet.
Quote from: Kitz Kat;436272
Not to thread-jack, but I have this problem too!
CoogarXR : 1985 Cougar XR-7
I have three letters for you: AOD:p
Quote from: thunderjet302;436277
When my car was AOD I still couldn't stand to drive it wearing boots.  The  pedals are way too close together.  One of the only real complaints I've ever had about my 'bird.
I agree the gas and brake are way too close. i seriously though about modifying mine when i did my t-5 swap, but time was an issue then. i ocassionally get my steel toes stuck under the break, but i wear a 15 wide...
How tall/big are you/ your feet that you keep hitting both pedals? Or what boots are you guys buying? I'm 5'9", 150, with a size 9.5 shoe and I can touch one pedal without hitting the other one. Of course I always were shoes when I drive.
6' 190 size 10.5 shoe.  I actually have yet to find another car where my feet are so comfortable.  I can go back & forth between the gas and brake in traffic easily.  The pedals are the right height from the floor as well.  I notice that my S197 pedal height does a number on my ankles on a long journey.
It would be easy to move the brake pedal as i did the clutch. If it's an AOD car, only one pedal to move. 5 speed, gotta do them both. I have had no issues yet. I just got my new clutch and brake pedal pads as well. I ordered them from 5.0resto...they have "5.0" on each one. Now to get the 5 speed Mustang gas pedal in. I've had it for 5 years on the shelf.
Quote from: thunderjet302;436285
lol...I'm only 6' 4" 215 lbs and wear a little ole size 14.  I guess that could be part of my problem, huh?  Tennis shoes are fine, but boots are really dangerous for me to wear and drive the 'bird.
Quote from: 50tbrd88;436322
See another reason why being over 6 feet tall makes life more difficult :p
6'5 And 190ish. Tennis shoes aren't bad as was already said. my steel toe is what really gets me. on an aod i keep my foot sideways and only use my toes between pedals.
There you go i am built to be a CAR GUY. Not only with my sharp mind but also a TALL ITALIAN. I am 5'6" 177 and my shoe size is 8. Perfect fit for those pedals. But i am still waiting to see the MOD VINNIE. Over the years i have modified many a pedal assembly. Looking forward to see what you did.
Note i am reading your posts and i am amazed at the size of you guys.(( HOLY ))  WOW. That is what i get being ITALIAN i am a short shiznit. But JR is big 6'2" 215 but he takes after his grandfather on my wife's side. Be safe and have a great day guys.
:bowdown:
I will try and have a picture up today. I'm 6' and 210 pounds, and have size 10 1/2 shoes, and those pedals being so close just wasn't working at all.
Interested to see pics of the mod!  Sounds like something I may need to look into someday.
