Topic: Tubular K-Member/ Coil-Over Kit (Read 7722 times) previous topic - next topic
I will be installing my UPR chromemoly K member (for a 79-93 fox stang) sometime in the next couple of weeks in the 88 TC. I mocked it up and after checking everything, it looks like a 3/8" spacer will be fine in the upper mount to frame area.
I am also going to use the UPR fox control arms. They should narrow the track width a little which is what I want as my front skinnies are all the away out at the edge of the fender opening and I would like to tuck them in a bit. If I remember correctly, it should move the wheels inboard approx. 1/2"-3/4" on each side.
TC#1- 2.5T- 10.14@134....9.76@138 with a 50shot
TC#2- Turbo BBF project
TC#3- parts car
What if your wanting to put in the tubed k - member from the mustangs but want to keep the 2.3 in the 88TC? I understand all the mustang suspension part are fox body
88 tc red, 5 speed daily driver/work in progress.
01 f150 4" lift, 35" tall mud tires, (needs a bigger lift)
88 tc black. New leather interior, motor is a work in progress.
They installed 4 cylinders in the Mustangs.  I pulled the 4 cylinder out of my Coupe and installed a 5.0 in the same K-member with no mods.  With that being said I would say that you could use a Fox Mustang tubular K-member and just use Fox Mustang 4 cylinder mounts to put a four cylinder in the car.  I would call someone like Maximum Motorsports to verify this before trying it though.
Darren
If I got the aftermarket Mustang K-member will the different motor mounts cause clearance issues anywhere in the Tbird?
So, we spent time getting THIS INFO together. It still needs data, as people get their hands on parts. Check out post #23 on dimensions for the 87-88 TBird/Cougar K-member vs the 99-04 cars...
Stock K-members are one thing. (Or several things, if you actually look at how much the dimensions changed. ) Casting about info on AM ones is another, when it comes to dimensions. Without hard numbers for control arm mounting widths and control arm lengths, it's a shoot. Check measurements, or just roll the dice.
The Mustang motor mounts *shouldn't* cause problems, but you *are* dealing with a 20+ year old car and aftermarket parts built for another application, so anything can happen.
