Topic: For the Turbo 2.3 fans: A bit of NHRA Stock Eliminator history was made on May 24th (Read 8680 times) previous topic - next topic
I was telling the guys at work about the t-bird, the were wondering what kind of HP and Torque your engine is making.  Any Idea??
Love Foxes, Birds or Stangs.
Quote from: MechanicMatt;434333
If you go to this site and plug in my weight 2825 lbs and plug in the times from the time slips, it will show the h.p. ( flywheel )
http://www.wallaceracing.com/et-hp-mph.php
11.828 et = 337
110.33 mph = 303 hp
The car is slowing down on the top end because I ran 113 mph at 11.86 back in April at a different track. I am not sure how accurate that track was on the mph because that was the first and only time I have ever been to that track.
both videos are of the same run:
[video=youtube;ilLKFqIQA1I]https://www.youtube.com/watch?v=ilLKFqIQA1I&list=HL1398108740&feature=mh_l  olz[/video]
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
[video=youtube;hHB8fwRv5dU]https://www.youtube.com/watch?v=hHB8fwRv5dU[/video]
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
The Wallace Racing website has some cool stuff on it. Thanks for sharing.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
93 Mustang LX 351C C4
2013 Honda CRV AWD
Congrats on the records!
Did you have to modify the wheel wells to fit those slicks?
1986 T-bird 3.8 *SOLD*
1990 Mustang
2004 Mach 1
Quote from: 83-88T-Bird Guy;434334
11.828 et = 337
110.33 mph = 303 hp
Do you know if that's flywheel or wheel horsepower? I plugged my GT40P combo numbers into the calculator (weight, trap speed) and it came up with 238hp. I had the car on a dyno with that combo and it made 235 to the wheels through an AOD. If it's wheel HP it's pretty close.
Quote from: MeanLX;434473
The lip on the inside has been rolled up to help prevent cutting the tire.
The car still has the original quad shocks still hooked up.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Quote from: thunderjet302;434475
Mine is probably flywheel h.p.
I would be amazed if that little 2.3 made that much rear wheel h.p.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Very cool!  Congrats!!!!!  :bowdown:
tbirdregistry.com
26480
27373
Quote from: 83-88T-Bird Guy;434482
I bet the more you get out of the car (ie less wheel spin, better 60' time) the more accurate. If you're cutting a 2.2+ 60' and running on street tires (me) it's probably not as accurate.
Quote from: thunderjet302;434522
^^ True.
The mph in a 1/4 mile run usually is a good indicator of the h.p. the engine makes.
The e.t. is an indicator of how well the h.p. is being laid down.
If you shift any vehicle at the optimum shift points, the mph will tell what h.p. you are making...usually.
My T-Bird Stocker has a fantastic 60 ft. ( for the e.t) and a good 1/8th mile mph, but the 1/4 mile mph is about 2 mph too slow, so there are exceptions.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Fantastic 60 foot times indeed.  Makes me want to throw the street slicks in the dumpster and get real wrinkle walls.  Insane traction!!
Quote from: MechanicMatt;434723
Yeah, what really blows my mind about those 1.51  60 footers on the TC is that the car still has stock 1986 upper and lower control arms ( un-boxed) All that was done is screws were put into the rubber bushings. ( old timer Stock Eliminator trick)
It even still has the factory quad shocks hooked up.
No subframe connectors at all.
I have no idea what the pinion angle is, and right now I have no plan to upgrade the rear suspension. It works so well.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Quote from: 83-88T-Bird Guy;434718
^^ True.
The better you can get a car to hook the more accurate the calculator is. In the case of my Thunderbird I dropped the 60' from 2.3 to 2.1 and picked up .3 seconds of e.t. And 1.4 mph. Did I gain hp? No. I just used the hp I had better.
In any case hp calculators are a guesstimate. The only way to find out how much power your car actually has is to dyno it.
Congratulations man!
Saw that videi being linked on YB, good stuff!
Go get those Super Stockers now! ;)
