Topic: Solved *NO* you dont just yank real hard- Turn Signal Handle (Read 5910 times) previous topic - next topic
the handle for the tilt on my Cougar was broken off when I got it.
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
Tilt lever unscrews. also has a flat spot so you can use a cresent wrench.
Jay that's crazy!!!!! Is that wood yours??? You must be a logger and heat with wood. man that is a lot of work even with a splitter!!! DAM!!! have a good night guys!
jay, arboristsite.com is another place Ive been known to roam.  Ill see if I can find a pic of my piped 3 cube Husqvarna.  Gotta mod anything with a motor, its a addiction.
Love Foxes, Birds or Stangs.
Quote from: TOM Renzo;434414
its a 2hp honda
1/2'' bell clutch driving 2) 120lb flywheels 18'' in diameter.
its a rack and pinion setup , no air, no hydraulics,, just simple centrifugal force.
old tech
What use to take me a month of afternoons to split by hand now takes just a weekend.
Loggers cut wood for a living and come back to the job sites later in the fall and cut up limbs and small wood.  They look at it as a waste to not use the whole tree, there is still money to be made from the rest of the tree.  They sell me a full size truck of wood stacked in the back tight for 40$ a load.
it makes them money, saves me time and yes i heat with wood..... nothing else.
