Topic: EATC question (Read 1288 times) previous topic - next topic
EATC question
Does the EATC head unit contain some kind of battery? Whenever my car sits for a couple of days, the temperature setting reverts back to 75 degrees. If it's only been a day or so, the temperature is where it was when I shut the car off. I have replaced the unit once already because of this. Also, on occasion when making changes in the temperature or where I want to direct the airflow output, it goes haywire and the display flashes and you have no control over the temperature; after the car has been shut off for a while, it resets itself to normal functionality.
Thanks for any info,
Rick
1988 T/C body with a 5.0 transplant. Motor has a Vortech V-2 supercharger, Edlebrock Performer RPM II intake, heads, FRPP F-303 cam, Comp Cams roller rockers, Power Pipe, LMAF, full Mac exhaust, lowered, Koni's, 5 lug conversion, Cobra wheels, 13" Cobra brakes, etc.
SOLD September 2020. Will miss this car after 19 years of building/driving/showing it off. Time for a new chapter in my life.
Dynoed 446 horse/409 torque at the wheels.
2003 Tenth Anniversary Cobra Convertible. 1 of 369 Torch Red made.
2021 Chevrolet 3500 dually, crew cab Duramax.
EATC question
http://www.coolcats.net/help/atc.html
i hated my eatc.
EATC question
Extreme temps; hot or cold, will make them go batshiznit for some reason.  99% of the time mine works as it should.  Temps near or below zero tend to make my blend door actuator move very slowly, which in turn makes the EATC angry when the car has sat overnight.
