Topic: 86 T-Bird window run weatherstrip (Read 13678 times) previous topic - next topic
Sure, glad I could help.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
93 Mustang LX 351C C4
2013 Honda CRV AWD
Appreciate the part numbers.  Just ordered the window run channels and the dew wipes!
Glad this has helped others to keep their T-Bird or Cougar looking good.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
2013 Honda CRV AWD
Dew wipe replacement update
I am updating my thread to show the revised method I used to replace the dew wipe on the passenger side of my T-Bird. I didn't notch the JC Whitney dew wipe as I did on the drivers side of the car. I first thought it would help the dew wipe to lay flatter but after looking at it while doing the passenger side notching them is not necessary. I have included two pictures to show this. Eliminating notching the dew wipe definitely makes it a much easier project as you only have to make one cut to the length of the dew wipe. I think the clips will be held into place better by not notching the dew wipe. I decided not to put weather strip adhesive on the clips either, as I did on the drivers side. I finally found another Tempo window run. Now both sides are finally done.XX
86 T-Bird V6 C5
91 F-150 5.0L 5spd
2013 Honda CRV AWD
? I have a 86 3.8  but no vent window
I'm not sure if these dew wipes will fit a non-vent window car. Hopefully someone will chime in to verify.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
2013 Honda CRV AWD
I'm trying to find replacement outer wipes for my 1980 Thunderbird...talk about impossible. At this point, I'd be happy to find a place I could just send them to to try to match them as best as possible.
My 80 has no vent window and has the sail mounted outer mirrors, so I need a wipe that's 38" long.
I'm not sure the ones I've used will work on your '80 T-Bird. Look through the JC Whitney Catalog or online. They have many different styles of weather strips and have cross sections and dimensions of them to compare to yours. There are some other companies out there who also have universal weather strips, but the names elude me at the moment. There are some vendors who sell varying types of weather strips that show up at the Carlisle PA Spring and Summer car shows too. Hope this helps.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
2013 Honda CRV AWD
Thanks for the reply. I was planning to get out to the Carlisle PA shows earlier this month but couldn't get the time to go. I just received a sample piece today in the mail, from a vendor selling what I'm guessing is Fairchild Industries part # 1369-4 molding. Its the same one as seen here: http://www.jcwhitney.com/p3039069/sku-225817.jcwx?filterid=d667y1980g2u0j1
The funny thing is when I look at it on the JC Whitney site it now says it does fit my 1980 base T-bird....whereas before it said it would not fit..... Weird.
It's a pretty close match, so I guess I'll order two lengths and hopefully if I make a few cuts and mods as required, I can get it to look close enough to factory... that no one will ever notice the difference.
Let us know how it works out. The things we have to do to keep our Birds in shape. :D
86 T-Bird V6 C5
91 F-150 5.0L 5spd
2013 Honda CRV AWD
Quote from: Fordracer08;449883
I'll have to give a report how it matches up. The molding s in fact,  Fairchild # 1369-4 molding, which I'm hoping to get cut to size, modified and attached...soon as I get a little free time.
My T-birds still in the body shop, but I need to get this molding swapped over onto the trim ASAP.
