Topic: What coolant brand/type are you guys running (Read 1701 times) previous topic - next topic
Wondering what coolant you are running.  Getting ready to flush mine and refill.
Can G05 be used on our cars?  If not what is a good brand, not sure about Prestone at WallyWorld.
Mike
Green stuff mixed 50/50 with distilled water. Works fine for me. Unless the car calls for something special I just buy Prestone or Peak and mix it with distilled water.
I think that G05 is pretty good stuff, just not sure how it reacts with the older cars with brass and solder heater cores and radiators.
Mike
I buy what's cheap or on sale
Got it, whatever is cheap is fine for these cars.  Just making sure, thanks guys.
Just wondering if I could run extended coolant in these cars, without hurting the lead solder.  Never-mind.
Mike
My reasoning is that these cars were designed for the regular green coolant so that's what I run in them.
With the extended life coolant I would be more worried about it mixing with any old green coolant left in the engine than what it would do to copper/brass parts. If extended life coolant mixes with the regular green stuff sludge in the cooling system can be a problem.
I have no problem doing a complete flush.  It sounds like everyone just sticks with the standard green, so Ill just stay with that.
thank you.
Mike
I flushed it completely out and filled with new G05 Zerex.  Should be good to go for a long time.
Now I only have to worry about Dexcool for my Chevys and G05 for my fords.  That way nobody can mess it up..... hopefully.
Mike
