Topic: 87 bird throttle valve adjustment?? (Read 4353 times) previous topic - next topic
Even once you have everything set up properly, you may find that you still have to let off the gas to go into OD. This is *basically* designed into the valvebody.
Regardless, though, you really should keep your foot in it until you reach the speed you want, and then let off so it "clunk"s into OD without a load on it. The OD bands and force from the servo are notoriously weak in these trannies, so you'll make it last a lot longer this way, especially if you use OD a lot. If you can, avoid using OD unless you'll be driving above 45 mph for at least half a mile.
forget it, the bird developed a tiny slip between 3 and OD, the next day NO OD..  seems theres not even one used t5 around my area unless I want to pay $600-$850...oh well , PLAN B ... I gota 5.0 sitting on the ground looking to hook a c6 on it. any thoughts on that?
For a 5.0, a C4 would probably do you better. C6 is larger and (from what I hear) harder to make fit in the fox transmission tunnel. Plus some HP is lost just turning that big transmission verses the smaller C4. If you don't want another AOD or a stick, I would get the C4.
CoogarXR : 1985 Cougar XR-7
holy ,someone should have told me how much of a PITA the trans. is to change in the tbird! crossover pipes suck!
