Topic: What did I do wrong... Spring question. (Read 6897 times) previous topic - next topic
I think your car should sit lower. You can see how mine sits in my sig. That's with stock LX springs and 225/55/16 tires.
Current ride height.
X
84 TurboCoupe with 302 .010 over - 9.8 : 1 Forged Pistons - Edlebrock Goodies:  Aluminum Heads #6037, Intake #3821, 65mm TBI/EGR #3824/3827, Camshaft #3722 -  Interactive System & Technologies Mass Air with 24# Injectors - A9L - 3g Alternator - BBK shorties, Cat Converter H-pipe, Magniflow lers - World Class T5 1352-169 (1986, V8, WC, 3.15 3.35 1.93 1.29 1.00 0.68) OEM Clutch Cable - 7.5 Trac Lock with 3.08 and slapper bars from 82 Mustang.
Looks like it has settled down a bit..?
Looks good, nice layout. ;)
I am still not happy with the height, I can't live with the front being higher than the back.  It settled a little over an inch.  I'm at about 2 1/4 gap from the 3.5 after install.  The back are moog cargo coils (I have a big speaker box in the trunk)
Spacers....air shocks....or new springs.
Does anyone make an adjustable rear LCA for these cars? If so, that would help as well.
1986 T-bird 3.8 *SOLD*
1990 Mustang
2004 Mach 1
CHE performance does and I think maximum motorsports does too
Quote from: custompunk;431443
X
Dude this looks nice and clean, aside from the front sitting a little high it is very well executed.
How does the front ride right now?
Hmm.  The Cargo Coils show a spring rate of 340 lbs/inch.  The 8599's are rated at 249....
A 225/60-16 works out to 26.6 inches...  How old are the rear springs?  The cargo coils shouldn't sit THAT low....
Maximum Motorsports sells adjustable lowers for these cars.  CHE sells adjustable ride height lowers and double adjustable uppers (nice for setting pinion angle).
The lowers:  http://www.cheperformance.com/prod-103.htm
The uppers:  http://www.cheperformance.com/prod-118.htm
As far as the cargo coils they are brand new.  They sit that low because I have a box with 2 12's, a full size spare, a floor jack, 2 jack stands, a 4x4 block of wood. and a 60 pound tool bag in the trunk. :P
Take all that  out of the trunk. If not, go spend $70 for a new set of air shocks, then you can level it out easily any time.
Sounds like about 200 pounds, +/-, that needs to find another place to reside. ;)
Yep. You really can't complain that the rear squats when you fill the trunk with all that junk. With all of that weight, if the springs didn't squat, then you'd have a car that rides like a 3/4 ton pickup.
I've got a stupid question.  Our cars tend to break just less than a full coil from the bottom, did you get the leftovers and the spring seat out of the control arm first?  If you're not looking for it it could be hard to spot.
X
Also, with having all that "stuff" in the trunk, it'll raise the nose some as the weight is behind the rear wheels. Empty the trunk and re-check your ride height. You might be surprised. Just my .02
John
Foe, are those black wheels from a crown vic cop car??
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
