Topic: Idle pulsation -- new issue (Read 3782 times) previous topic - next topic
And without a tps code, non of that should have anything to do with his problem.
You have to adapt a Fox Mustang 5.0 HO tps sensor to make the 65mm explorer throttle body work.You will not be giving the pcm the correct signal if you use the explorer tps as the voltage range is different on both types of tps sensors.
 here is the link you need. I do not know your car but I have to assume that you are running HO stang electronics if you are bolting on a 65mm tb.
http://www.veryuseful.com/mustang/tech/engine/ConvertingExplorer65mmTB.pdf
1985 Turbo Coupe
1988 Thunderbird Sport
1996 F150
Quote from: Pro SC;431794
this is the same write up i got when I bought the Explorer 65mm from ebay.  Weird thing though,  the TPS that came with it had a different connector but the screw spacing was identical.  The thing I'm noticing now is that the surging has pretty much stopped.  the only thing it does now is occasionally get 'caught' idling too high when I start it warm -- and it will continue too high until I turn off the engine and restart.  then it is perfect for the rest of the drive.
Have you done a base idle reset?
Quote from: thunderjet302;432022
nope but I'll look that up now.
Quote from: marianadeeps;432043
Here ya go: http://sbftech.com/index.php/topic,1031.0.html
Quote from: thunderjet302;432054
thanks jet!
