Topic: SOOOO bloody close.... (Read 4750 times) previous topic - next topic
Quote from: vinnietbird;430622
If that's an a/c line, it should be aluminum, and I'd think it could SLOWLY be bent forward to clear.
the factory lines were steel
Is there a specific custom shop online I should go to to make sure the fittings will work with my A/C unit? Nothing has ever gone right with this car so I really dont want to order a custom part and have it come in but not work... (It has happened in the past)
Pull the line, bring it into any local hose and rubber store/shop.
When I worked on the bosses custom stuff we did this all the time. making one from scratch was cheaper most of the time then modding an existing line. you might be able to get away with a 90 or 45° adapter.
Oh I got the darn pipe bent... Using some amazing tools I might add!
Awsome
Fire and a bfh lol
