Topic: pictures 1987 cougar whole car for parts (Read 2448 times) previous topic - next topic
The dash trim underneath the main dash bezel..... the pieces on either side of the steering column....  How are they?  I'll take them if they are clean.  Zip is 11735.
i'll get pictures over the weekend ...
Quote from: V8Demon;431699
Thanks  ;)
do you have a 88 0r 87 fog light set up like wiring, switches
one mounting hole for large trim is oversize and  small trim has 2 tiny drilled  holes on underside  i also have the  trim  under column in beigh color  pdolb1@verizon.net
Quote from: Ralph-O;431805
no fog light option ..but if ford installs fog light wire harness without the foglight option then i can get  that out i didn't look for the wires ....pdolb1@verizon.net
