Topic: Huge scare about 45 minutes ago....... (Read 11626 times) previous topic - next topic
I was having some battery power issues, so, I took the car to Autozone and had it checked. Bad battery, so, I got a new one. I figured since I was cranky about shelling out large dollars for a battery, I'd go treat the Sport to a bath. So, I went to the car wash, washed the car, did a little spray shine and tire treatment, and then left.....Here's where it get bad....On my way home I was driving about 45 mph down the street and I felt the Sport DROP on the rear driver side. I saw the tire flying through the air, and the car went to the left quickly. I ended up in the median on the grass. I assessed the damage, and luckily, the body and all are in great shape. The rear brake assembly...dead. The wheel...broke in half. The tire looks o.k though. Pics tomorrow of the minimal car damage and busted wheel. My brake drum is MIA. All of the lug bolts were in excellent shape. I think somebody loosened them. I checked the others and they sem tight. new locking lug nuts, a wheel and brake asembly have to be bought, and the brake cylinder. .
Quote from: vinnietbird;429221
Whaaaat!?  That's crazy...  Glad you and the body are OK!
Brian Leavitt
86 TC 5-Speed -- MS2x w/COP | 83lb. Injectors| T3/T4 50 Trim Stage 3 .63AR | Full 3" Exhaust - No Cat | Motorsport FMIC | Ranger Roller |
------------------------Ported E6 | Walbro 255HP | Kirban | Pierburg EBCV @ 20psi | BOV | 120-amp 3G | K&N Cone | 8.8" 3.55 rear |
87 TC 5-Speed -- Cone Filter | Bypassed BCS | Stock Daily Driver
66 Mustang -- Pertronix Ignition Upgrade | Slow-Mobile
WTF? How did that happen? Does somebody want you dead?
Looks like it may be a good thing I bought those parts from you. That does really suck though
Vinnie, anything in particular you need?  ..if I have it, it's yours man
Glad you're ok...the Sport is some nicely arranged pieces of metal, and can be fixed...I doubt there's another V-man floating around out there ;)
Thanks guys. I'm glad I'm fine, too. LOL. My biggest need is a brake drum. It's from an earlier model Fox Bird. A little deeper than the '88 model. I had swapped the brake stuff years ago and now I'm looking for another. Gotta ask Chuck which one I need. he is the one that told me what I needed. So, that's what I'll be needing. I'll order a new wheel asap, too.
whoa! Glad you're ok--there are few things worse than watching your wheel head down the road beside the car.  It (losing a wheel) happened to my teenaged brother right after he had slowed from highway speeds to in-town speed, but unlike you, he had only put one lug nut on (finger tight).
That's crazy.  Glad you're ok.
Wow glad you and the car are in one piece
Vinnie, i am glad your ok, and no major damage........ it's really odd, because that happened to me with my Bird in 1987 after i brought the car in for a wheel alignment and tire rotation.  The genius kid they had work on my car didn't tighten my Driver front rim down, and it came off my car at about 50+ MPH.  It was a miracle that there were no other cars around me cause it was after midnight and was out cruising alone.    A really nice guy driving next to me saw it happen and pulled over, let me jump in and we found my runaway rim and tire a 1/4 mile down the road on a side street.  I even located all four lugs in the road.  I went back to the shop the next and 2 co-workers had to pull me off the kid. (I was a kid myself back then) He felt super bad about it, and apologized like fifty times.  I went to the boss and begged him not to fire the guy, let him learn from the experience.    My only real damage was the front disc itself which ground down flat partially from the long spark filled skid to a stop.  Speedy recovery!
So odd that this showed up on my Facebook news feed. Small world. I now see that my 4 lug brake parts can not help you even if my 5 lug conversion was complete. At this point in time, I don't see anything I can do to help, but if there is just let me know. Apparently, you can reach me in more than one way. lol
How did the wheel break in half? This should never happen.
I'm glad your alright and no major damage.
Quote from: vinnietbird;429229
I'm a little rusty on that, but it sounds like you may need one from an '86 7.5 rear?
Of course, I will defer to Chuck on that, however. But it seems like when I was doing my big 5 lug drum research, that the odd width rear had the proper depth of drums, but in 4 lug, so hopefully that's what will get you in order.
Anyway, if you need a sway bar, I've got 3 or 4 of them...Stang GT sized, which IIRC, are the same diameter as the TC bars..?
Beau, I'd be very interested in a rear Turbo Coupe/GT sway bar. Mine has a pretty wicked flat spot on it now. May compromise it's strength. PM me and we can make a deal.
I'm going to OEWheels and ordering a new rim right now. Then, one step closer to repairing the damage.
