Topic: fulcrum vs stud heads (Read 3854 times) previous topic - next topic
Quote from: jcassity;430148
that looks like my stang intake, an 83ho,, I think,
Wha?? I thought '83 HO used a 4bbl alu intake...
I just did a water test on the heads i got from 86T-bird i mention earlier in this thread using water.
I poured water in all the intake and exhaust valve chambers and not a drop escaped around the valve seats
i thought water would be an unfair test because it can escape from anywhere,,, but it turned out i was wrong.
these things are all assembled, i hate to take them apart.  i guess i will leave well enough alone.
has anyone ever used water to check valve seats?
im pretty happy with the results
Use carb cleaner not water.  Molecules are smaller.
Darren
Best
ok,,i see your point,,will do.
I may ping you again on the whitness mark your showing
