Topic: Fuse box diagram.... (Read 5669 times) previous topic - next topic
Reception is good.  Antenna needs to "see" out through the glass so I don"t think it would work from inside the housing.
Gotcha. Thanks a lot.
Quote from: hwy73;429007
i cant speak to your reception but can to the window part,, not actually true.
turn your radio to AM band and then go to a channel that comes in but has some static
while in a parking lot, drive in a circle and listen, the windshield of the car will collect and bounce the frequency .
"certain sloped " rear windows would have oem antennas in them but mostly antenna are found in the windshield because of the surface area and angle to collect the channels.
vinnie, next time check out the table of contents of the evtm's, that helps narrow down drawings or prints your looking for.  the front table of contents is very accurate,, there is a typo in the 87evtm though.
Thanks for the info.
