Topic: Tbird sport Hood & nose to TC hood and nose (Read 2962 times) previous topic - next topic
has anyone noticed any issues matching up the lines of the hood when you drop in a TC hood & TC header panel on a sport ?
we seem to be coming up with a gap along the area where the header panel meets the hood and from dead center moving to the left or the right,,,,,,  the gap seems to get wider.
Maybe you need to realign your fenders. It shouldn't make a difference as far as the body goes. A Sport, a TC or a 3.8 car....still the same basic body.
My autox car doesn't line up quite right either, but I think the frame had been tweaked slightly.
This is a 1988 Hhood according to the Vin number and 88 nose and header panel
If you zoom in on the line I am showing the gap gets wider on the far left and far right like the header panel is bent or stuff just doesn't lineup
Looks fine. Most of these cars are like that and came from the factory that way.
Not gonna get much better. Well not without some bodywork on the nose
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
my cougar doesnt do this at all,, the two corners are matched perfectly.
ideas?
can anyone else confirm thier hood gap along the header when closed?
for some reason im starting to think this header panel is kinda bent,,, being fiberglass not sure if thats possible but just throwing that out there.
I think it would be interesting to take some measurements from the windshield to the header panel and even measure the hood. It looks to me like there is just something out of alignment somewhere. Looks like maybe that fender is sitting just a little forward of the other one. Just curious also, did the gaps look the same when the bumper cover is attached and all the braces in place? From the photo it looks like the problem exists on both sides, but is just more noticeable on the passenger side. Another possibility could be that since the car did get a frontal impact that the core support where the brace attaches in the center could be slightly bent and that is pulling the center of the header panel in a little further than it should be.
I need to see the gap at the fenders and doors, and the gap at the fenders and sides of the hood.
It may be possible to move the center of the header panel forward and then move the hood forward to close up the gap.
Looks way better than the gaps on my car...
It's an american car, it's not a Maserati. It's built by Bob from Kentucky while he was eating McNuggets!
Quote from: bodyman;427429
i didnt think of that!!!!!!!!!
that would play into the suspect that the header is "straighter" than it should be.
im gonna go see now.
that worked perfectly,,,
loosened the header to bumper cover bolts and header to radiator core braket,,,
ran a wratchet strap around the header and hooked other end to my work bench
pulled the header center forward 1/8'',  locked it down.
loosened hood bolts, scooted hood forward a tad,,, all is well in the world of my boy!
will post pic,, my phone is charging now.
jcassity
Good to hear that it worked, awaiting photos.....
