Topic: Parting out two 88 Turbo Coupes (Read 22013 times) previous topic - next topic
Just in case you all forgot about me. I still have lots of great parts. Let me know what you need.
How much for a hood?
This might be an odd one. Do you have a "turbocoupe" trunk lid emblem in good condition?
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
X
I may have another. I'll have to wait until it gets light and see if the parts car I just bought has one.
the vertical bracket in the left hand side of the trunk, to hold the spare tire....is the one in your parts car any good?  The one in my cougar is rotten out.
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 3.8 V6 - Rescue
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 5.0 V8 - Survivor
Do You Have A Passenger Door In The Baby Blue Color For The 87/88?
...and there was light!
Quote from: Driverguy;426181
Yes, the ones in my Tbirds are all good. Those are welded in though aren't they?
Quote from: T-BirdX3;426191
I sure do!!! Pretty sure the paint is good too! I know the paint is good, just not sure if there are any paint chips or anything. The car had been repainted and it looked good. No rust! $75. Come and get it. I am about 10 miles south of Manassas. All of the window and track are out of this one as well as the door lock actuator, but I do have other doors that we can steal the glass and tracks from.  I have the drivers side also. Oh, and the door emblem is also gone. XX
Hi, does this car have an electronic climate control unit? If so, I am very interested in taking it off your hands!
let me know! thanks.
Quote from: kylesburrell;426197
I have a couple of these systems. Are you looking for just the control panel or the heater box or both? Let me know and send me your zip code and I'll get you a shipped cost.
Quote from: 50RACER;426194
Im not sure...i know the horizontal piece is welded, and the vertical piece is tack-welded to it...but the bottom of mine is completely gone, so I have no idea how it connects to the car, or if the spare tire well is the same on the thunderbird and cougar
im looking for the climate control unit that is located under the radio, and above the panel with the cigarette lighter. My zip code is 20124.
Do you have a good fuel rail from one of those turbo coupes?
Quote from: Ramos617;426310
I answered your other post before I saw this one. Yes. I can ship you one for $30.
