Topic: Considering selling my Cougar (Read 3881 times) previous topic - next topic
yep,, suckin too much gas..
if your making a habit of driving in D instead of OD on faster roads... that wont help.
you want to sell it, use a paperclip to pull your codes after its warm.
With CFI, its pretty much the same various parts that fail on SEFI.  The ECT / TPS /ACT & MAP all get involved in dumping the signal to to the EEC to supply a ground to your two injectors.
this way you can sell a car that you know is working right.
my full size bronco 351 gets 12mpg and thats normal for the 6800lb hulk.
It's not that the cel is burnt out, there simply is no cel on this car!
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
Purchase a cheap code scanner for obd-1. The connector port is under the hood. If ya don't wanna spend the $20 you can use an anlog voltmeter to read codes
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
I ran out to AZ and got a cheap $4 test light, it did the job! It looks like ECT AND TPS are the issue (if i read them right)
could have pulled codes with a test light or a cheap digital multi meter.
replace the tps for sure.
did you run the test when the car was warm? if not that could be a false code.
oops, misread your post, thought you bought an actual scanner. fix the tps and let us know.
Bear with me, because I'm not sure I counted them right, but I got these from the scan: 14, 15, 18, 21, 31, 53, 61, 83.
Not sure how to get the TPS off, the fast idle cam assembly interferes with removal of the TPS. http://www.foxtbirdcougarforums.com/showthread.php?36574-High-idle&p=422976#post422976
reference codes here.
 http://oldfuelinjection.com/index.php?p=14
are you running codes with the car on? all the codes I saw referenced to continuous memory codes. double check the codes. if you want, make a video and upload it, that way you can re check, and everyone else can.verify.
I got these KOEO
after looking at your codes, you have an erratic pipe sensor code. generally this means the pip in the dizzy or the ignition module (on the distributor) is bad, causing a loss of spark or intermittent miss. there are actually a few sensors not working that you really should replace.
yep, the pick up module in the dizzy is not hard but can be hard if you have not done it before.
I pulled the neg cable to clear the codes, now the only one coming up is 83
continuous memory codes are only stored for 20 key cycles. if you had those codes, you had those problems.
Bump - might be interested if you're still considering selling.
T-Birds can't fly.  Ask how I know...
