Topic: Alarm (Read 1574 times) previous topic - next topic
Alarm
I need a wiring diagram for an 87 LS, im going to install a Clarion Ms2007 wich has been sitting around here for a while, The wiring diagram I found doesnt have all the wires like door locks and stuff, idk if you can get a diagram with that or not but it would be a ton helpfull..
thanx
Re: Alarm
Door lock wire bundle runs: From left door switch and motor, through door jamb rubber bellows, down behind left kick panel (pick up power from fuses 8 (ltgreen/yel) and 12 (blk/wht)), along left door sill, under driver's seat, over hump, under passenger seat (relays there too), up right door sill, up behind right kick panel, through door jamb rubber bellows, to right door switch and motor.
Ground any pink/yellow, doors lock.
Ground any pink/lightgreen, doors unlock.
