Topic: Buying new block (Read 3684 times) previous topic - next topic
Buying new block
Rod it is. The pistons are FORGED FROM THE FACTORY and the crank is strong. Floating pins serve only one purpose. EASE OF ASSEMBLY. Not every piston can be a floater. most Forged pistons come with spiral locks so you can float the rods. Floating the rods eliminates the heating process for pressed in pins. A rod heater is a must to assemble non floating rods. By the way once again every engines weak point is the rods. Unless you are running an LS motor then it is the BOLTS!!
Buying new block
kk
Buying new block
Well the block had a crack in it and a chip out of a chunk of metal. So I am guessing it was dropped...
