Topic: Sudden loss of oil pressure. (Read 10994 times) previous topic - next topic
Jay i have been blue printing pumps for many years now. Here is a tip for you. Gear end play is around .004 on just about every pump on the planet. Increasing the end play is very bad. I do not want to scare you but when i build pumps for any engine i always save the old plate from the old pump. And then i use Plasti gauge to see what the gear to plate clearance is. Same as checking a rod bearing clearance. Once i get the clearance i want by shaving down the case i use the old plate along with the new one with longer bolts. This prevents the plate from curling and messing up the pump seal. But you said you shimmed the plate with gasket material. Buddy that is big time bad!! I do a lot of Buick GN and GNX cars and those pumps have a gasket. reason being the pump is built in to the front cover and it is external. That pump comes with several thickness gaskets to get the required .003 clearance. We use steel shims or gaskets in stead of normal paper or velemoid gasket material
i just measured my fish paper,, its .014 thick,,, hi-jack over
Not sure what you mean by high-jack over? What is the actual end play of the driven gears? If more than .003 - .005 it is out of speck!
Thanks i did not understand. You know i am OLD!!
Ok, engine's out, and here's whats up.
The remains of the pump shaft
X
The pump housing.  In the lower half of the pic, you can see a ding in the aluminum, which is actually raised into the cavity.  Also, whatever did this also left a good deal of scoring in the housing in the upper section of the pic.
X
The outer gerotor. Whatever caused the damage to the casing struck here, too. the damage lines up on both.  Unlike the housing, this is steel.  The two points of damage will not pass one another.
X
Tomorrow or Monday, I'll pull caps and check oil clearance.  Any theories?  I can't explain how anything got past the pickup screen.  I inspected it, and it's perfectly intact.  I'm cautiously optimistic.
Possibly an internal failure, poor quality control.  I had a 95 5.0's oil pump poop the bed with only 33,000 on it
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
Found out what got in the pump, and it puts her up for the winter.  It's rebuild time.  I'm really really bummed about it, but I've decided to look at it as an opportunity.
X
Busted up piston skirt.  Busted by the oil pump drive I thought was safe in the bottom of the pan.  Fail.
Still, if I HAVE to buy pistons, I suppose it wouldn't hurt to buy some -3cc domed KB's.  If I HAVE to have the heads off, I get a chance to port the GT40 heads and intake.  If I HAVE to have the crank out, I might as well have it polished and precision balanced with those KB pistons, you get the idea.  Anybody have a TFS stage 1 cam they're looking to get rid of?
well , there isnt any "real knowing" how this happened,, you can speculate all day long.
did you find the skirt part(s)? does it/they match up to the piston?
like you, id be thinking the whole engine is contaminated, you might have caught it in time but i agree warrants a tear down.
let us know the pn to the oil pan gasket,,,,
i love the oem explorer gaskets and that on you show.
I found several large pieces, but also many small pieces that could pass through the screen.  I took the pan off on the stand full, and poured it through a fine mesh filter to find all the particulates.  There's no telling where any others might be,
Hopefully id didnt marr up the cylinder wall. Sucks man. Hope everything checks out alright
10 over may be good enough,, we went 20 to get everything roundy again.
