Topic: Who's got $5K for a Thunderbird (Read 2073 times) previous topic - next topic
Quote from: Haystack;422841
I might get flamed for this, but I think our cars make very good winter drivers, as well as daily drivers
everyone in a while you find someone who is realistic. I've gotten either very lucky, or cars just aren't worth anything here
I just bought my 86 5.0 for $500.
my 87 5.0 was $400.(tv cable came off. no od)
last 87 5.0 bird was $400.("didn't run". swapped fuseable links, was in very good condition.
87 bird 5.0 before that was $400 (bad engine and trans unfortunately).
87 3.8 v-6 cougar $300. new trans, bad body.
87 3.8 v-6 cougar. $550. Good body and car  died to a bad waterpump.
86 5.0 cougar. $400. needed a starter solinoid.
86 5.0 cougar. $110 police impound. million miles, bad body.
if you put a bit of work into a "non-running" car, you can get pretty good deals.
Agreed. Except the V6 cars I've had have done better in the snow than the V8 cars I've had.
Quote from: thunderjet302;422839
So you're getting another Panther to drive in the winter? Why a rot free Box? If you're going to winter drive it might as well get a cheap 98 and up Vic. Who cares if that rusts to hell.....
I'm in the midst of a big struggle lol. One, I hate the thought of being forced to let something waste away. Two, I want something unique to be seen in and to experience every day. I really love box panthers, and I get a lot of compliments. And I've still got it stuck in my head that I can successfully rustproof one, if I only start with something that is perfect save for maybe a couple of surface-rusted body mount bolts or something like that. The blue one really isn't *that* bad, there are just a couple of coin-currency-sized places in the trunk that were always there, and recently I jammed a screwdriver into them and they blew through. Same with a really small spot that was visible on the driver's front door corner. There is a 1/4" hole that exists 1 inch inboard from the corner of the passenger rear lower quarter. I had thoroughly removed all loose flake on the inside when I bought the car, I sprayed WD-40 and other products on the inside and outside of this a few times as it got dirty. It's still dirty and grey-black both in and out, and this hole hasn't gotten any bigger in 5 years. That has to prove something.
The trouble is that I'm an engineer and I won't take "insurmountable problem" as an answer. I wish I could move out of the salt belt....
Quote from: ZondaC12;422867
I'd like to have a unique DD but living in the salt belt I bought a brand new Focus. I won't feel so bad when in 10-15 years the salt gods get it. Some times you have to suck it up and drive a "normal" car. Maybe ;).
Quote from: Cougars 2 go;422847
They do make good daily drivers but in some places of the country (here) salt will claim the cars long before a mechanical issue will.
Quote from: thunderjet302;422896
Yeah... I haven't driven any Cougars in snow for 10 years and don't plan to any more anyway.
Quote from: Cougars 2 go;422908
If I lived somewhere where it didn't snow/get salted I would rock a Fox-body as a DD.
we use a lot of salt here and it snows. in my opinion its the constant humidity you guys get along the coast and back east. I can't imagine I'm doing anything different.
