Topic: The age old question (Read 4590 times) previous topic - next topic
yes. boost was limited and it had a different turbo. everything else is the same.
Quote from: TheFoeYouKnow;422545
Quick check for 5.0 guys:  Raise your hand if you've got a "stock" 5.0 still.
You can't see it, but I am NOT raising my hand.
Bone stock 5.0 in my 87......for now!
:popcorn:
what if we added a 2k budget to modify the car, then what?
$2000? Hmmmm.....
8.8 with good gears
 GT-40 heads
H.O cam (since you have flat top pistons)
Explorer intake
65mm throttle body
headers, new dual exhaust
Speed Density computer
19# injectors
1.6 roller rockers
new fuel pump
associated gaskets
And if you're lucky, you'll still have enough left for gas. Then, it'll feel like a crazy bada$$ car for you.
My experience, from racing a TC against a 5.0, both of which I owned:
When I bought my parts '87 TC, I was driving it home to strip it, and my buddy was driving my '88 5.0. Both cars were bog-stock except the 88 had 2-1/4" duals with no cats and the TC had a Magnaflow catback, and we played with each other the whole 30 minute trip (should have been more than an hour, but there you go). I can honestly say that neither car was faster than the other. I could not catch the '88, nor could it lose me. This was driving a rural road with a fair bit of twists & turns mixed among some nice straightaways. The TC definitely outhandled the '88 though. Any time we approached a bend I would be right on his bumper, but then at passing lanes I'd get beside him but couldn't get by him. Again, neither could he gain on me. Even on a mile long straight stretch both cars were evenly matched (the TC's speedo was showing around 200km/hr, or 120MPH toward the end of this straight stretch). Mind, the 88 was a low mileage car (47k) and in pristine operating condition, while the TC had about 130k on it (the odometer was around 220,000 km) and was on its final journey, so that might have played a role, but even with 130k the TC seemed to work fine. Also, while the '88 was a 5.0 car it was a very basic one: Power windows, locks, mirrors and A/C were its only "features". The TC was fairly loaded. I know it's not scientific, but that was my experience. And what an experience it is, by the way, racing against your own car :hick:
And that being said, from those experiences, I would also guess that the '88, once it had the T-5 and 3.55 TC rear in it (the original rear had 2.73's), would have handily outrun the TC that the rear end came out of - bottom end, anyway (or probably anything under 100 MPH). Higher end, the lack of revs would have killed it. And with the poly front LCA bushings, CHE rear arms, Bullitt springs, subframe connectors, brand new Monroe sens-a-trac struts & shocks on all four corners, and TC sway bars & brakes it would have outhandled the stock TC too. In fact, that '88 became the best handling car I'd ever driven after those mods. That car was absolutely FLAT in turns, and it just plain went where you pointed it.
Unfortunately, although it handled exceptionally well, it also transmitted every single road imperfection through to the occupants. You could run over a squirrel and tell what it had for dinner. This ruined the car for me :punchballs:. I should've listened to Chuck, when he warned me against the poly bushings...
I still have one
Quote from: teal9550;422582
then you can have a 5.0 like in my 87
Quote from: daminc;422598
I still have one
You have one for now........
its still going to end up being stock... just SEFI instead of CFI... :hick:
On the TC end a 2K budget for a car that already handle great could be:
bigger injectors
quarterhorse
bigger turbo
wideband (for adjusting tuning)
walbro 255hp
full 3" exhaust
K&N cone filter
Kirban adjustable
That in it self would definatley boost a TC's power. And if you dont go new on everything, but hit up ebay and places like turboford. Alot more could be done.
I look at it this way:
If you've got a 5.0 keep it and mod it. You can get a bunch of power out of it and it's cost effective as it's already in your car.
If you've got a 2.3T keep it and mod it. You can get a bunch of power out of it and it's cost effective as it's already in your car.
If you've got a 3.8 do what ever you want. Just get that thing out of there if you want to go fast.......
H/C/I on a 5.0 a set of 4.10s a shift kit, 125 shot of nos and 28x10.50x15 slicks ebay parts and your at 2k or less and I'd bet you'd have a high 12 sec bird
I had a 90 and a 93 with the 3.8, so I know how much they suck!
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
