Topic: Anyone Have Issues With Headlights going off? (Read 5517 times) previous topic - next topic
Ryan yours just has plain old cheap 9004 in it. If you can hold the dimmer switch back and they work its probably the multifunction switch, Id have to look at a wiring diagram to make sure theres no bypass though before Id say for sure.
So I swapped em this afternoon as they shut off and on all morning on the way to school. so far I tested em for a few mins and they still shut off on high beam but on low they didnt seem to be shutting off. I'll make sure this is accurate on my way to college tomorrow. so is maybe the switch bad then? I did notice one part of the plug for the headlight/turn signal switch in the column was kind of burnt when i changed it.
Drove to school this morning on low and so far they didnt go off.sucks that i cant use brights :(
The Joy of Cougar Headlight Problems.
I've been having some problems with my 1988 XR7, low beams intermittent, highs were working mostly steadily.  Mine was definitely the multifunction switch on the column.  I could smell it being hot when driving at night for any distance.  I took it apart last night and one of the contacts in the hi/lo portion of the switch had melted down into the plastic a bit and the plastic was gooed up around it blocking the connection.  it also kept the switch from alternating contacts to switch from high to low reliably.  I'm thinking this overheating must be a design flaw.
I did notice that if I hot-wired the lights direct to the battery they were considerably brighter, I think the engineers undersized the wiring for the load, similar to what they did with the Gen 2 alternator to cause all those associated problems (like, oh, catching fire :)
I'm going to replace the switch - 55 bucks locally.  Although I got the hi/lo working again, for now, the detent for the turn sigs is broken and I have to hold the turn switch to activate it, cheapie pot-metal it looks like, snapped in the middle of the detent.  I've got two relays and I'll wire them in on a fuse link straight from battery to the lights, and just use the wiring from the bulb connector to energize the relays.
These lights were so bad when I got the car that I hit a deer I couldn't see until I was right up on it, standing in the road.  Way dim, and I'm going to either swap front clips  (eventually) for an 86 style, moulding be darned, or throw some 4666 bulbs in the sockets with the front plastic removed (they fit snugly but it'll need adjusted by a shop with a beam measuring tool.)  4666 sealed beams might just be the way to go, but it loses the aero look on the front with sunken headlights which sucks, the original plastic does weird stuff to the pattern, which is pretty good from the sealed beams.  Tried sanding and polishing the original plastic but that didn't go well. :)
Relays should definitely help by getting that 15-20A load out of the dash/column harness.
Cabby
Quote from: camelid;422736
Cabby
Yeah I've replaced the switch in the column which includes the turn signal part that ur talking about being broke but i'm sure u know that.
Which it was melted from getting to hot but it was still getting connection. I might need to do a seperate circuit like you are talking about but now that I know more about electricity i'd want a foolproof diagram on the setup to make sure it wont be just as bad.
also i've found that using a mr clean magic eraser helps a TON on the old lens but u just gotta use regular lense cleaner after you use that or it'll still leave a film.
sigh. drove to class this morning and they shut off about 5-6 times :( so back to the drawing board
Not really like said before all you really have to do is a headlamp model like phone and my instruction show
The mods I did released all energy and wants across the multifunction and the headlamp switch
Without auto lamps makes the task slightly simpler and at the end of the day you get to send direct Battery power out to the headlamps without the resistivity of a headlamp switches internal moving parts
In the EV TMs foe I have in our signatures you can actually go drill into the pages showing the  main light switch and there will be a certain little iconic symbol illustrating the thermal circuit breaker built inside that headlamp switch itself
A relay mod for your headlamps and marker lamps is all that needs to be done
I personally wouldn't stop there that I would go ahead and do a relay mod for your irrigation and accessories circuit as well to relieve heat off of your ignition switch
All this stuff is posted in the electrical text section
Quote from: jcassity;422805
well after i get the headlight switch change if it is still doing it i guess i'll have to do the relay mod.really hate to have to do it though.
If your headlamps are still switching off and on do not do the relay modification
There must be another problem
Like mentioned earlier there is a thermal circuit breaker made inside the headlamp switch which would be the primary culprit for switching headlamps off and on
You have already mentioned you swap the headlamp switch out
When I get back to my office I can look at some wiring  diagrams to try to put two and two together
This sounds kind of tricky
Again do not do the mod
Quote from: jcassity;423145
i bought a switch from a member on here. got it upt in this evening.so far on high beams it hasnt gone out yet. ill test em on the way to class in the morning and see how they do
Those switches are overloaded by design. Slave it out or you will have 2 bad switches. The circuit breaker is internally in the switch and it is NG. Replace the switch and slave it out pr0nTO!!
Quote from: TOM Renzo;423211
I agree 100% Tom!! Once Im sure all electronics in my new to me TC are good, thats the 2nd thing being done.
yes you need to get a relay for your headlights. i had the same problem, and solved mine but buying a relay off ebay. i also bought one for my foglights, I put in new headlight switch and fog lamp switch, along with putting in a new plug sense mine was burnt on the headlights. I also put in a new dimmer switch off the colum.
listen to these guys they know what there talken about.
The relay is what you need or your just ganna keep blowing threw switches, and I would get rid of the auto lamp as well. Ive read plenty of threads that they just become a pain in the ass.
88 tc red, 5 speed daily driver/work in progress.
01 f150 4" lift, 35" tall mud tires, (needs a bigger lift)
88 tc black. New leather interior, motor is a work in progress.
auto lamps are not a pain in the ass, you just need to understand it and not write it off.
name another automatic system that has ran this long without failure.
its design is pretty good.
you just have to RTFM ~evtm and shop manuals that is.
