Topic: tail lights not working (Read 5909 times) previous topic - next topic
Yes, both the front and rear parking lights are powered by the same section of the switch.
The front lights are working and the cluster illumination relay is being energized.
We know the relay is being energized because the speedometer LCDs go out. The relay transfers the LCD power to the dimmer section of the switch and none of the dimmer controlled lights are working.
The front parking lights are powered directly from the switch and the rear lights are powered through fuse 15.
Since your test light shows power at fuse 15, the tail light problem is down stream from there.
The dash lights are powered from the dimmer through fuse 13.
Since your light shows power at fuse 13, the dash light problem is down stream from fuse 13.
I had you check both test points on the fuses because sometimes a fuse can be bad even though it eyeballs good.
So I will have a broken wire or bad ground
Check any brown wire you can get to at the tail lights with your test light.
Pull the ashtray illumination bulb and probe the socket contact. (I hope that is easy to get to)
Quote from: teal9550;422704
Could be, but there is no common ground or wire for the two problems.
I do appreciate all the help I'll do more checking tomorrow
Diagrams
More diagrams
dude you are awesome thanks!
I know he is I swear to God I don't know what the world would've done without him
I haven't had time to look at it today but I'll be working on it tomorrow morning for sure
Ok so I tear out the instrument panel and start looking and testing wires with no luck so I decided to look at the fuses one more time just to make sure so I stick my head under the dash and start testing and they are all good except now I can see because my head is burried under there that number 13 & 15 fuses are missing completely so I pop them in and low and behold I have tail lights I'm going to put a heater core in it and put the dash back together and see if it all works
oops
Doh!!!
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
When all else fails always start at the fuse PANEL. No Fuse No power no lights SIMPLE!!!
Right I just don't understand why those were taken out, I think my buddy may have pulled them when we making the brake lights work, he replaced the switch for me he's a small guy and I'm on the larger size so it's hard for me to fit under there
