Topic: 88 t bird t c (Read 1413 times) previous topic - next topic
88 t bird t c
i need some help is there a fuse for the abs relay if so where is it located on the car
88 t bird t c
YES Fuse link N On the starter solenoid
88 t bird t c
is it near the battery
88 t bird t c
Actually
ALL Data says an 87 and 88 are different. His post said he has an 88 !! They both come from fuse links from the starter solenoid.
87 HD Pump Link C Relay is link  B  16G
88 HD is S link and relay is T  16G
So the link you want is T Black 16G
I also gave you the wrong fuse link N That is from the ignition switch to the ABS sorry. I read your post to fast i just noticed  you want the Fuse link for the relay. My Mistake Sorry i stand corrected it happens.
