Topic: I think DART lies.... (Read 5571 times) previous topic - next topic
I had 215/60-15's and it hooked like a cat on carpet. Twisted the output shaft in the AOD in half which led to the t5 swap. after the t5 swap it saw 4500 RPM launches on a fairly regular basis and it still hooked like mad. Never had any problems out of my mounts or the set that was built for my buddys t-bird that also had a 5.0, but with an AOD and 1 wheel peel, his didn't hook
86 Mustang GT
Torque link from competition engineering will solve any motor mount worries. I love mine. Best thing i ever bought for under a $100!!!
1986 Ford Thunderbird
!!COMPLETED!! 427 ci ROUSH engine swap<<!NEW! Fed by a Holley Terminator EFI setup/ custom COP setup ignition
 8.8 rear. with 4:10 gears, Eaton Trutrac diff, 31 spline axles and external breather system. Had it cleaned, sandblasted, and powder coated.
Holley Terminator EFI with custom made CNP ignition system
"Its kind of like driving the red headed step child of the mustangs" :hick:
The only thing i can think of is the motor mounts got put together backwards. I know when i dropped my 302 in i set it down (mind you i have an aftermarket kmmber and stang mounts) somthing looked off. Had the motor mounts on wrong sides
Like i said though, my motor mounts have a stud on the botom of the driver side one and the stock k member has a clearance hole for that stud only on the driver side, meaning it cant be switched, and if i swap the top plates around, the trans isnt even close to fitting in the crossmember holes.
