Topic: Parting Out (Read 5628 times) previous topic - next topic
Parting Out
Some things in life are more important than play toys, such as paying off my debt so I can buy a house for my family... So, I am now parting out my 88 Turbocoupe. If anyone has any parts interest, please reply to this or shoot me a PM. I will be updating this and listing the bigger/more commonly sold items over the next few days, but just trying to generate interest.
Headlights- SOLD!
Corner lights- SOLD!
Header panel- $75 as is, $125 if I sand, fill, and prime. has large paint chips but no cracks or anything that I see
PRC covers- $5 each
ABS pump- $150 Brakes worked perfectly fine on the 20 mile drive home, only time I ever drove the car
Hood with scoops and ducting- $75 as is, $15o if I sand, fill, and prime. has a small dent about dead center
Fuel Rail with AFPR- $50
LA3- $50 has a hole cut in one end, looks to have been chipped at some point in time, no chip now
Headlight switch. Contains panel dim, headlight, AD, AL, and fog switch- $25
Dash clock- $5
Antenna, fuel, and ride switch- $15
Trim panel for above switch - $5
Auto Dim sensor- $10 unknown condition
Window Regulators- $25 each
Large VAM- $50
A/C condenser- $25
Shifter bezel- $10 boot is junk, but there
Intercooler- $50
T5- $250 unsure on mileage, original cluster was MIA when I bought car, shifted good, no funny noises. fluid looked great.
Hydraulic bellhousing- $50
Slave cylinder- $10
Clutch master cylinder- $10
Clutch fork- $20
Short throw shifter- $50 unknown brand
Driveshaft- $35
Electric fans- $25
Square style intake manifold, upper and lower- $50
Distributor- $15
Valve cover- $20 as is, $75 if I clean up, sand, and repaint
Engine harness- $40
PRC/ABS harness- $30
8.8 with 3.55 gears complete rotor-rotor with calipers- $200
Spindles- SOLD
Front calipers-$20 each
Doors- $40 each
Front fenders- $25 each
Snowflake wheels. Have 5 total, only 4 caps though (i think, might be able to round up a 5th cap)-$25 each, $100 for set. Have never tried cleaning them up, but they should clean up
All prices are OBO plus buyer pays shipping
86 Mustang GT
Parting Out
How about the little pull strap covers on the doors?
Parting Out
I'm looking for a 5 speed shifter bezel .
Parting Out
What color interior?  Condition of the seats?
Mike
Parting Out
Looking for a hydraulic clutch fork.  Is it a 5-spd?
Parting Out
Vinnie, are you looking for just the bezel or the bezel and boot?
Yes it is/was a 5 speed. Shoot me a PM with an offer on the fork
86 Mustang GT
Parting Out
I am looking for the drivers side power window regulator W/ motor. I would also be interested in the passenger side as well. They must be in perfect working order.. Mine just failed.. Please PM me a price shipped to NJ
Thanks
1987 Cougar XR7 308 S/C
Trick Flow Heads/S-Trim/42lb. Inj./Stg. 1 cam/4.10 Detroit Locker,Yukon Axles,T/A Rear End Housing,CHE Upper Control Arms,Chucks Poly motor mounts,
Working A/C -- BBK Shorties/ H-Pipe/ Flowmasters/ Eibach Springs/SSM lift bars/ Max Motorsports subframe connectors/3300 stall convert/ etc....... list keeps going
Lots and Lots of Parts to make you go FAST !!
2008 Mustang GT - - Dark candy Apple Red
Roush Louvers;18" Polished Bullit Rim;3.55 Posi;Hood Scoop;Pypes Exhaust
Parting Out
edited original post with some parts and prices
86 Mustang GT
Parting Out
pm sent
Parting Out
Just the bezel. If the boot is , leave it as an assembly so I can use the clips and such.
 Let me know how much.
Parting Out
Vinnie, hate to say it but upon closer inspection, one of the corners is broke. If you still want it for the small pieces or whatnot, just pay for the ride and it's yours
86 Mustang GT
Parting Out
I appreciate it, but I'll continue the search.
Parting Out
I have an automatic bezel out of a 83, but that probably wont do you any good.
86 Mustang GT
Parting Out
I need the passenger side trunk hinge. From what I can tell, it's held in by a stamped pin of sorts. Is that possible you could grab that for me?
