Topic: Friday the 6th.....3-30-14 new pics..... (Read 57075 times) previous topic - next topic
Reply #240
If tomorrow's weather holds out, I'm swapping the axles and sway bar (Thanks again Jangus). I also got the brand new IAC in the mail today as long as the new Ford racing bearings and seals for the axles. One piece at a time. Need a vacation. One week and I could make a lot happen. Off for three days, but the weather is supposed to go to  tomorrow night....of course it is.
Reply #241
Ever notice the weather is always cold/precipitating every time one wants to/has free time to work on a car outside?
Reply #242
I've noticed it. LOL.
I JUST got finished swapping the bearings, seals and axles, as well as new fluid of course. No test drive yet. Still putting tols away and cleaning my space. I also just got my stereo from the Fed Ex guy, so, hopefully before tomorrow is over with, SiriusXM will finally be a reality. More news later after a test drive.
Going out to finish cleaning and install the new IAC.
Reply #243
Well, this week looks py as far as the weather report is showing. Friday is a high of 69 and partly cloudy. HOPEFULLY I can get the trans in on Friday. Getting closer by the week.
Reply #244
It hasn't been 60* here since November..... Good luck getting the trans in. Hopefully the weather holds for you.
Reply #245
More to do.....Kitz is sending me the heads for the car. AFR aluminum pieces. That can't hurt the Sport. A bit excited about that.
Reply #246
That's way cool
Reply #247
Today....... I installed the brand new gas struts for the trunk lid. Two 40# struts are perfect. Pope the switch, and the trunk lid slowly raises up. The wind doesn't blow it shut either.
I also finally got the new stereo installed and the Sirius XM satellite radio functional. Nice. Now, I have to spent a little time tomorrow figuring out how the whole stereo works. LOL.
 I am HOPING the antenna for the satellite radio works well. I put it in the rear window, in opening of the third brake light that faces the glass. I figure after the windows are tinted, it'll never be seen. I can't have the antenna stuck to the body with a wire following it. Not cool. So far it seems to be fine. I'll know for sure tomorrow when I have time to take the Sport out.
Reply #248
Didn't get a lot done. Fabbed a new access panel for the fuel pump in the trunk, and looked at the new valve covers. I gotta do some serious thinking to decide if I'm actually going to use them. I bought them late at night, and wasn't thinking so clearly. I'll need a one inch plenum spacer to use them which isn't a big deal. And I do have the hood clearance. LOL. Thanks for that Jerry.
Reply #249
I fabbed the new access panel for the Sports fuel pump access in the trunk. The other panel was not how I wanted it, so, made the new one. I also installed the new gas struts for the trunk lid. No more torsion bars. The wind can't close the trunk, yet it's still very easy to close. I fabbed the floor mounts and the hinge brackets.
Reply #250
Looks good man
Reply #251
Thanks. Good AND functional.
Reply #252
Trunk lid with the struts turned out great Vinnie. Those torsion bars can be a %#@! to get back in place! Been there done that. LOL.
 S O L D
Reply #253
Mine can't go back in. I taped them together, cut them in half, pulled them out and tossed them in the trash. LOL.
Reply #254
Lol
