Topic: Earliest 1983 TBird (Read 25885 times) previous topic - next topic
Earliest 1983 TBird
Reply #60
Quote from: thunderjet302;451628
Or a way to shrink full size cars to matchbox size and then make them full size again when you want to drive them ;).
you are a genius, i know just who to call.......
https://www.youtube.com/watch?v=0W_ph68w6SM
Earliest 1983 TBird
Reply #61
I was thinking of this guy actually https://www.youtube.com/watch?v=U68aYI5LhvM
Edit: I just realized that movie came out when I was 4 years old........
Earliest 1983 TBird
Reply #62
Quote from: thunderjet302;451640
Im so old, i fart dust.
Earliest 1983 TBird
Reply #63
I'm not that old yet. I think ;).
Back on topic a bit. On your current 83 how late was it built? I'm curious if the wiring color coding matches an 83 car or an 84 car. My 88 Thunderbird is a very early build car (4628 off the line) and it has some odd overlaps with an 87 car. For instance the wires are color coded to an 87 car but it has the vss sensor wired into the engine harness,  something no 87 car had. Also being an early build car it has metal rear window trim instead of the rubber trim.
Earliest 1983 TBird
Reply #64
There are almost always some overlap near end or beginning of year...
The '86 Grand Marquis my uncle ordered for my mom(he owned a dealership) near end of '86 production had a set of 1987 plug wires and the wedge base 3157 tail lamp bulbs, those were supposedly not used till '87...
Lowest Lorain VIN for '83 is 101147 which is likely one of the first '83 off their line(As long as we're counting in the first 1500 or so)... For Atlanta first is 118617, followed by 119737, 120667 etc which likely indicates Atlanta was building other models prior to and along with T-Birds, so VINs prior to say 115000/117000 are all for what other model they built... I know in the late '60s & early '70s ATL built Full Size & Torino, those VINs were assigned in sequence irregardless of model or build day...
VINs are always assigned on paper/computer as they are received from dealer, on the line 123456 could be built days or even weeks apart from 123457... Note early builds are likely built fairly close together, but if there is a shortage from supplier for say blue leather upholstery(yeah bad example), those builds could be held up a few days/weeks till the product arrives at assembly plant...
Earliest 1983 TBird
Reply #65
So parts overlap from one year to the next isn't that uncommon for late/early build cars. Makes sense as they are probably using up leftover parts.
Earliest 1983 TBird
Reply #66
You would need a De-Bigulator to shrink them. Unfortunately making them full-size again would require some sort of Re-Bigulator, a concept so ridiculous it makes me want to laugh out loud...
Earliest 1983 TBird
Reply #67
Quote from: thunderjet302;451651
Sorta, there are parts from some years that just can't be used as there was a major change in model year(IE '86 to '87 Bird/Coug)... The '86 to '87 Grand Marquis was virtually the same car...
I've never seen a '88 Turbo Coupe with anything other than the Hitachi alt, by same token all '87 apparently had a Ford 2G...
Earliest 1983 TBird
Reply #68
The lowest 1983 T'bird VINs that I am showing in my VIN lists are....
Atlanta
V6: 115600
V8: 115650
TC: 139002
Lorain
V6: 100001
V8: 100005
TC: 109822
The lowest 1983 T'birds that I have entered into the database are....
Atlanta
V6: 118617
V8: 145008
TC: 143965
Lorain
V6: 115295
V8: 108275
TC: 122371
Earliest 1983 TBird
Reply #69
Reason the Atlanta VINs start so high in 1983 is because that plant produced more than one Ford model that year.  The (Fox) LTD was also produced there.  The first 15,599 VINs assigned at Atlanta Assembly in 1983 were LTDs.
Earliest 1983 TBird
Reply #70
Remember this YT video I posted last December?
https://www.youtube.com/watch?v=P5Ju4E4ej9g#t=38
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
Earliest 1983 TBird
Reply #71
Quote from: FoxChassis;451673
Atlanta
V6: 115600
V8: 115650
TC: 139002
Lorain
V6: 100001
V8: 100005
TC: 109822
Atlanta
V6: 118617
V8: 145008
TC: 143965
Lorain
V6: 115295
V8: 108275
TC: 122371
Quote from: FoxChassis;451674
Great info!  Thanks!!! :cool:
tbirdregistry.com
26480
27373
Earliest 1983 TBird
Reply #72
Yeah I figured Atlanta was producing some other model just wasn't sure what...
Assuming a later introduction, the 100005 first V8 VIN surely falls outside normal production, was likely a pilot/preproduction model... Generally preproduction applies to the first few builds with VIN less than 100050... Guessing the lowest Atl VINS are preproduction as well, those don't really stand out...
Before Norfolk Assembly closed I knew a couple supervisors... They'd generally build a few next year preproduction models a few weeks prior to ceasing current production(looking for assembly issues that may need modifying), those always had extremely low VINs
Earliest 1983 TBird
Reply #73
Very few early V8 VINs at Lorain in 1983..
1FABP46F9DH100005
1FABP46F2DH100007
1FABP46F4DH100008
1FABP46F5DH100017
1FABP46F5DH100051
1FABP46F0DH100054
1FABP46F4DH100056
1FABP46F0DH102886
1FABP46F3DH104969
1FABP46F0DH105058
1FABP46F4DH105175
1FABP46F2DH105188
1FABP46F4DH105189
Earliest 1983 TBird
Reply #74
Quote from: FoxChassis;451702
1FABP46F9DH100005
1FABP46F2DH100007
1FABP46F4DH100008
1FABP46F5DH100017
1FABP46F5DH100051
1FABP46F0DH100054
1FABP46F4DH100056
1FABP46F0DH102886
1FABP46F3DH104969
1FABP46F0DH105058
1FABP46F4DH105175
1FABP46F2DH105188
1FABP46F4DH105189
The ones through 0056 are likely pilot cars... VINs were possibly reserved could have been built weeks apart...
Do you have any other info on these cars??? For pilot cars generally DSO is 89 for Home Office Reserve, often these are test mules and not sold(though some are)... I had a '76 Stang II that was 100026..
