Topic: We just bought an 87 TC Parts Car (Read 6576 times) previous topic - next topic
Blkbrd88 pm me your addy an i'll send that assembly to you.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Quote from: 1BadBird;421080
PM sent..........Thanks
Speed is just a question of MONEY How fast can you go?    (M. M.)
Pull the actual igntion switch off the column and slide the swtch part around until you see some activity thats the only trick that i know
Ron, I sent you a pm. Call me please.
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Package sent Ron
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Received today, Thanks.
Ron
Not a problem, glad to help. Again I'm sorry to took so long. Hope it helps you get it started.
John
PM sent too
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Ron, I sent the refund finally.
John
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
That color TC is rare. look it up. i had a 87 that color, and if i remember the only made a handful. wish i kept that one.
You did get the refund, right?
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
well dang it,,, for the record....... and late is better than never.
look on the bottom of the steering column...
there is a rod that goes down into a light tan & aluminum housing thingy which is the ignition switch.
slide the bar one click forward that that will be run
slide the bar one click back and that will be accy
slide the bar one click forward then press further forward and that will be start.
we at he cassity house need a turn signal assembly if you can spare it.
sorry for the late response !
Quote from: jcassity;424090
PM me your address and I'll get it out to you. :-)
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Quote from: 1BadBird;424072
Yep, sorry for the delay....haven't had internet service for more than a month.
Thanks for the info, I will try that tomorrow & let you know the results.
Ron
I possibly have a whole steering column for a TC, but I can't say for sure, 100%. I can check wednesday though. Would it be easier to swap a column into it? It's a PITA to get to the bolt on the steering shaft, but other than that, it's 4 nuts under the dash and the wiring connectors.
If you want my cell to text info back and forth, PM me and I'll respond. :)
If thunder doesn't have a TC steering column, I have one It'd be wiling to let go. It's been in the corner of the garage for a while, it'd like to see someone use it.
