Topic: Don't drill without being absolutely sure what's on the other side (Read 3558 times) previous topic - next topic
Quote from: thunderjet302;420104
My favorite "stupid car mod" was an 88 Mark VII I looked at before I bought my 91 Mark VII. The owner had added a subwoofer. He ran the 12 gauge wire from the trunk through the interior and through the door jamb. Every time the door was shut it would pinch the wire. It was starting to chafe when I looked at it. I passed on the car as if he did that I can only imagine what other "repairs" were hidden.
I know a guy that uses 14 gauge wire (the kind that comes in the rolls at Autozone) for amp wire. He cannot figure out why his amp and the wire get so hot. He also doesn't use a fuse, just wired straight from amp to battery. He refuses to believe that 14 gauge is to small for any amp, much less his 500w RMS 2 channel. He has it ran through the door jam as well. He also says that you never need a fuse "If you know what you're doing"
I'm just waiting for his truck to burn
86 Mustang GT
Quote from: Dougy_Fresh;420118
Does he work in the limousine coach building industry?
Quote from: Cougars 2 go;420113
Yeah, you would have been dancing the 60-hertz shuffle.
That's why, when I'm drilling into walls at home, I use the drill bits that won't go through metal. Better safe than sorry :hick:
Quote from: Cougars 2 go;420133
So basically the guy I met isn't the only dumb ass when it comes to car electrical wiring?
