Topic: 83 tb 5.0 electrical questions (Read 1772 times) previous topic - next topic
ignition wire on starter solenoid not getting 12v, I have it at the column (hot when in crank mode with key).  I think there is a plug in between somewhere?
dash lights, clock light, ash tray light, and a/c control not getting 12v at the bulb plug
Blinkers not coming on when turned on
Acc 12v where radio goes does not have 12v
I check power spots in the fuse holder, look good on both sides of fues
I have power for low beam and high beam, tail lights, brake lights, hazards, cigarette lighter plug, and clock works.
Just curious if I missing a main plug or ground somewhere?
I did take out the column from the 84tb v6 car and put in for the tilt steering, plugs plugged right in.
Sounds like stuff isn't connected at the fender solenoid/junction.  When converting to a PMGR starter, you still need to keep it.  I wont bore you with the details of the procedure, as I'm sure you did your research.
Yea i got a diagram for that starter.
X
X
X
I think I see what fender plug your talking about (3rd pic), but I have a set of other plugs on the driver side that are not plugged to anything. (2nd pic)
and (blue wire going for horn?)
I have a slim rectangle plug over by the passenger slide that I thought went to the voltage regulator. (1st pic)
Please keep in mind on the pictures, that the wire are tuck in side finders.
And I took out shifter column, not sure if there is a safety switch somewhere?
NSS Not cut threw!!!
I will try it tomorrow, thanks
update, that worked tom, thanks
I took out the light switch, it was all corroded up, so I cleaned the one I had from parts car and made sure to use contact cleaner and made the spring and contacts clean.  Now I have 12v from the light switch and it dims my test light.  but I don't have power at the bulbs, so I jump a wire from the cigarette light constant 12v and the light works, not sure where from there.
Blinkers are now working
No 12v acc at radio
Ok got the bulbs working, and got the blower working, I am finding that the dirt dobber have caused some connection issues.
