Topic: why is there gas in my oil (Read 3409 times) previous topic - next topic
Are u using a mechanical fuel pump?
Nevermind i just seen u are fuelie
So i pulled the vaccum line on the fpr and cranked it over nothing came out.Then i pulled all the plugs and the one at the front of the block was soaked in gas.Gonna order some injectors for it.Any suggestions on what brand i should get and where i can get them.Thanks for all the help.
I would just get a stock replacement one.  Should have them all over ebay.  What engine and year car you got?
Mike
Good now you have found the issue. Change all the injectors and the oil and filter and do not forget to change the FUEL FILTER ALSO. And drive off in to the sunset happier than a CLAM. Good Job and Good luck.
I still suggest running codes.... do a engine cylinder balance test and KNOW which injection needs replaced.
I have a nice set for sale. http://www.foxtbirdcougarforums.com/showthread.php?35857-Accel-14lb-and-19lb-mustang-fuel-injectors
Stacks just a QUESTION!!! Did he not say he found the flooded cylinder???? And why in the world would one run a cylinder balance test with a leaky injector with diluted  oil??? Maybe he should run it on a DYNE that would be even BETTER!!! The part i do not understand is he said nothing about a MISS ???????? He may have a cylinder issue this is not over yet. I would suggest a compression test after he drains the oil and changes the filter and pours in some fresh oil. Just a thought!!!
:toilet:
