Topic: 5.0 CFI to SEFI Upgrade (Read 29890 times) previous topic - next topic
Reply #60
Quote from: daminc;445854
I'm very confused about this now
Sorry for all the confusion.
On your CFI the injectors are pulsed without regard to the position of the crankshaft.
86 and up 5.0's have SEFI. The S stands for sequential and means the ECC pulses the injectors in firing order sequence.
It pulses each injector when its associated cylinder has its intake valve open and on its intake stroke.
The SEFI distributor has one PIP pulse that is a different width than the other seven. The EEC uses this to get in sync with the crankshaft.
Does your distributor have the round rotor with two screws holding it on?
If so, reread TurboCoupe50's post# 53.
The standard armature is probably what you have.
The signature PIP armature is what you need.
The armatures are what your rotor bolts onto.
Reply #61
Quote from: daminc;445858
I think I see where everyone is going with this.....
I am not going HO
I am not changing the cam
I am just making my engine SEFI with everything that it already has in it.
so the question is...will my distributer work adding the upper and lower intake, changing the wiring harness, and using a standard SD computer with a fuel rail and 14# injectors
Well. No. The SEFI computer uses a different PIP module and vane arrangement in the distributor than the distributor you currently have in your 85. So basically you need a distributor from an 86-93 5.0 Mustang, 86-88 5.0 Thunderbird/Cougar 5.0, or 86-92 Lincoln Mark VII. Then you'll need to have the steel gear on that distributor swapped to a cast iron gear like you have on the distributor currently in your 85 Convertible. Once you do that you'll be good to go.
Edit: I'm wrong. The PIP sensor is the same from 84 and up. You just need to swap the CFI vane in the distributor to a SEFI vane.
Reply #62
so is this part able to be swapped in the dist? or will it be something that is not going to just bolt right in?
has anybody ever done this before?
Reply #63
I feel like I'm pioneering this swap....lol
Reply #64
Quote from: daminc;445862
Theoretically you should be able to just change the part by removing the rotor and the two screws below it holding the "vane" assembly on. Theoretically.
Reply #65
Quote from: thunderjet302;445866
I'll give it a go
Reply #66
If you have the round rotor, I don't think it can be removed.
Reply #67
Correct, at least theoretically... :hick:
For that matter with a known width one could use a dremel and cut the finger down...  I'll have to look again but I believe the smaller finger is offset, meaning the material was removed from one side, would have to be that config or there could be two #1 cylinders...
Quote from: softtouch;445868
Correct, at least theoretically... :giggle:
Reply #68
what does the round rotor look like
Reply #69
I'm also willing to take a dremel to it too...whatever it takes to remedy the situation
Reply #70
Looks like this... But isn't listed for 1985...
http://shop.advanceautoparts.com/p/bwd-distributor-rotor-d204p/5202558-P?searchTerm=distributor+rotor+button
Still apparently there two rotors for '85 or maybe Advance just has both rotors listed... One is located by the opening in the vane disc(type the one I pictured uses), the other apparently has a flat on the dist shaft that sets position...
I'd say it's very unlikely vane discs would swap between the two styles...
Reply #71
this is what I have
Reply #72
I suppose  tomorrow, I could try to swap the one from my 87 to see if it fits or bolts up to the 85 dist
Reply #73
Quote from: daminc;445876
this is what I have
I see two screws on the top of vane plate, appears to be replaceable...
Pull the rotor off and check to see if it has a finger at rear that fits into opening on vane plate... If so thats the common one most, if not all use from '86 up...
Reply #74
Quote from: TurboCoupe50;445869
I remember reading somewhere that the leading or trailing edge of the vane is used for ignition timing. So it is important to cut off the correct side of the correct vane. So you don't have one plug out of time.
