Topic: 5.0 CFI to SEFI Upgrade (Read 31690 times) previous topic - next topic
Just a thought here in case these fittings would be an option for anyone wanting to adapt from AN fittings to the injection fuel rails (they are black and about half way down the page):
http://www.russellperformance.com/mc/adapt_fit/fuel-efi.shtml
Darren
Hey Jerry I got some of the things you need, let me know. some mass air stuff to.
daminc, I did a swap similar to this about a year ago on my 85(3.8 to 5.0). To be able to use the ’96 Explorer fuel rails, I used the fuel lines coming off the rail and used Dorman fuel line connectors PN# 800-130 & 800-131, they are listed for a 1996 Ford Explorer 5.0, and attached them to the stock CFI fuel lines as shown below.
X
Also here is where the lines meet the fuel rail.
XX
Quote from: jcassity;418614
the exporer fuel rails source and return both dump down along the rear of the engine,, thats a perfect match to "about" where your screw on CFI lines stop.
the fox body sefi fuel rails all come in up front on the pass side engine bay,,
what im saying is that your car/chassis design is compatable with the explorer fuel rail design ~less the connectivity and figuring that out.
your green top injectors you have now (thats what you should have) are 34lb / hr high resistance.
The 5.0CFI came with blue top 54lb high resistance injectors and a much larger air tunnel ports and trottle plates.
simply install your green top injectors into the 5.0 CFI and you move more air.  you will notice that the v6 cfi air tunnel ports dont match the much larger EGR spacer plate.
The 5.0 CFI air tunnel matches up perfectly.
The CFI splits in half via 4 phillups screws from the bottom... basically the 5.0 lower half cfi has the larger air tunnes as compared to your v6 CFI lower half.
i highly recommend a speed handle and an apex tip phillups bit,, these screws are a  to get out due to they corrode.
one good and basic reason for lack of power right off the top of my head is...........
--- remove cfi 4 nuts and linkages ect
---the rear gold looking drivers side vac line fitting will likely be carbon clogged once you flip the cfi over and see the problem, chip away all the stuff that doesnt belong.
---the hesitation you feel when flooring the gas is a gas flow problem.
---remove the injector screens and vula, no more hesitation... i and others chased this issue down for months and most of us having no codes or no problems with our engines,, of course im on a very small team of people who tried it and liked it.  shiznit can the screens, they are a restriction for the small motor,, thats what your fuel filter is for.
Scott, I'm gonna check the carbon buildup, and injector screens this week....
you know I don't have a V6 CFI, right, your confusing me a bit with the V6 and V8 info...
awesome... I see now why to use the explorer rails... thanks for the help and the links everyone...
Kitz, I'll be in contact after I see what I'm missing for this swap.... I guess I'll be looking for an Explorer fuel rail next.... anybody got one kicking around
I wonder if Scott is keeping his off his new explorer motor? sorry for the bad info, I thought 83-85.5.0 were all the same.
I found an Explorer fuel rail already.... or I should say, it found me this afternoon... lol
:burnout:good info guys!!  I enjoyed the info and pictures on retrofitting.  Keeps my wheels turning
ok back to this upgrade.... I'm making a list of parts to swap for this. I'd like to make this a complete list for future reading.... let me know what I'm missing in my list and I will update it
parts needed to swap 302 CFI to SEFI
lower intake
upper intake
throttle body
injectors
fuel rail from an explorer
distributer
wiring harness and computer
throttle cable
Aod tv cable
If you are going SEFI with a Mustang computer (you would have to if you go MAF) than you would also need a HO firing order cam. If you have a Thunderbird/Cougar SD computer than you could stay SD and stick with the cam you have. If you're that far into it you might as well stick a HO cam in. If you go with a roller cam make sure you use the proper gear for a roller cam on the distributor.
I'm not planning on going that far with this motor.I don't know the first thing about installing a cam or anything else in it. I would build another while I kept this one on the road. I drove this car 20 miles since last year, and if you ever drove a cougar vert, you learn that going fast is not the safest thing to do..... I cant even imagine how that thing would fold up without having a roof on it, if it was in any kind of accident.
I got all SD stuff already from before I upgraded my 87
...Old thread, but I feel I should point this out.  A newer style distributor is going to have a hardened steel gear on the end.  These are intended to be used with roller camshafts.  Use of them on a non-roller cam will cause issues....you know.....turning your camshaft gear into metal shavings that will show up in your oil pan and pump pickup screen.  The non-roller distributors have a cast iron gear.
 In 1985 the manual transmission 5.0 equipped Mustang was the only Ford product to have the steel gear.  If it had a manual trans in it it had a carb on top as well in 1985. All other 5.0 equipped cars got the swap to the steel gear in later years as the swap to roller cams was made.  If you're gonna keep the stock camshaft, I suppose you could swap a cast gear onto a newer distributor.
I wanted to find this very thread last summer doing my sons build,, I asked the question and there wasn't much popular concern about it... I knew we had this discussion a while back.
we ended up using an HO roller cam against his oem 88 bird dizzy.
see any issues with that?
Quote from: jcassity;429731
Nope...
As far as swapping gears it sounds simple but I've read there isn't a actual location for the hole... In other words the gear is pressed on, hole drilled then pin inserted... A pirated gear from another dist may have the hole too high or low for your dist. plus they are not always on center, so pin won't fit at all...
