Topic: 5.0 CFI to SEFI Upgrade (Read 31669 times) previous topic - next topic
Reply #105
Quote from: softtouch;445927
So surgery on the 85 is not an option?
well...there's going to be surgery.... but not for this part of the project..
I'll keep everyone up to date as I do the SEFI conversion, and also with the rest of the car... I want to paint it before winter hopefully
Reply #106
I mean will cutting some off the 85's vane not work or did you just decide not to do it?
Reply #107
cutting it should work fine, but I got one on the way with the rest of my upgrade parts
Reply #108
Thanks. I just want to salt that away for future reference in case it comes up again.
Reply #109
Cool. You should be good to go.
I checked the PIP on O'Reilly's website and the Motorcraft one interchanges from 84 up to 93. You won't need to change out the PIP which is good. You have to disassemble the distributor to do so.
Reply #110
yes take 3mm off the correct one.... not sure how it knows which is the 1st and 8th one though especially between standard and HO
Reply #111
Quote from: thunderjet302;445939
well, thats a plus
Reply #112
Quote from: daminc;445940
8 precedes 1 in both cases. SD 15426378  HO 13726548
Also the same pairs of cylinders come to top dead center at the same time. That's because they have the same crankshaft.
SD 1&6 5&3 4&7 2&8-----    HO 1&6 3&5 7&4 2&8
 So when #1 is top dead center for ignition #6 is top dead center for injector pulse.
Reply #113
Good info. Wonder why the change in firing orders? Less vibration, (for SO/5.0 trucks), or more power f(or HO applications)?
Reply #114
Quote from: ThunderbirdSport302;445957
When the 351 came out in '69 Ford said the different firing order was to revise bearing loads... For power I doubt there's a difference but with a performance exhaust system the 351/HO pattern defiantly has a deeper note to the exhaust... It wasn't obvious in '69 as the Windsor exhaust systems were fairly restrictive but when the free breathing'70 Cleveland debuted, didn't sound like any Ford engine prior...
Reply #115
Quote from: TurboCoupe50;445972
I think it was something about front a rear main bearing loads. The rear main bearing on a Windsor (302/351) is thicker than the front main bearing. The 351/HO firing order fires two cylinders sequentially on the larger rear main bearing, the 302/SO firing order fires two cylinders sequentially on the front main bearing. Apparently the 351/HO firing order is better for engine life.
Reply #116
Makes pretty good sense. There's a local guy that runs a 5.0 truck in the local mud hole circuit...has a stockish 5.0, and headers and some sort of exhaust, or no exhaust, maybe. Definitely sounds unlike an HO. The bearing load thing, that's new to me, but a good thing.
Reply #117
Crossfire between the 7 & 8 plug wires with the SD/Carb sequence  used to be a problem. The stock routing crossed the 8 wire over to the opposite side of the bundle so it wouldn't run parallel and close to #7 wire.
7 firing just before 8 messed up the 8 plugs ignition at certain RPMs. Can't remember the details anymore. Haven't heard it talked about in recent years, maybe better quality wires have reduced the problem.
Reply #118
Quote from: softtouch;445983
You know now that you mention it I have a very old receipt (from sometime in 1990) about the number 8 plug fouling on my Thunderbird. Turns out the ignition wires were going and number 8 was crossfiring. New wires solved the problem (and it was fixed under warranty). Yes I have receipts for work done on my Thunderbird that go back to almost when it was new.
Reply #119
Yeah the HO order fixed it alright, now are four wires Ford has routed away from each other...
