Topic: Brake line check time! (Read 3791 times) previous topic - next topic
Re: Brake line check time!
Freind of mine had a caliper bolt come loose before. Guess I should fix that e-brake.
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
Quote from: amooset
In the process of bleeding the brakes, the rear line decided to pop, just to torment me.
Oh man that one had me cracking up!  :giggle:  :rollin:  Those kinds of jobs always go that way dont they?
Foxless :(
The last time I had a total brake failure was in my '50 Plymouth about 50 years ago.
It is worrysome to hear that losing the front brakes is a total loss.
The rears a supposed to be a separate hydraulic system.
How come that does'nt work?
well if your talking about that 50 plymouth it probably has a suicide cylinder on it.
But if your talking about the fox cars, they have two pistons but only one resevoir.
Yes I know the '50 Plymouth had a single hydraulic system.
The reservoir on the Foxs has two compartments, one for each system.
I had a rear brake line on my '78 Pinto spring a leak. The pedal went lower, but I still had the front brakes.
Is it possible people are driving with no rear brakes and just dont know it? Until the fronts go out?
Drums hardly ever work on any cars.  Self adjusters like to sieze
the drums work on all three of my cats....
If lubed and assembled properly, it has been my experiance that drums work just fine.  In fact, they are the only way to have a parking break that will not seise in a northern climate.  Disk type parking breaks (ie turbo coupe) will not last long in a corrosion pr0ne climate.
Many drums don;t work because people install the adjuster backwards, do not lube it with that special break parts grease, or reuse rusty break hardware.
