Topic: 88 sport rebuild , need advice (Read 36105 times) previous topic - next topic
Reply #210
You'll want them in the pipes.  You can't just tie them back.  At the very least get some nuts from the hardware store in the same thread as the o2's, cut holes in an opportune position below the headers and weld the nuts on.  Then you can mount the o2's.  This won't guarantee that you get in the exhaust stream correctly, but it's worked for me on other cars in the past.  It depends on how finicky this car is.
Reply #212
I wouldn't be bothered by leaving them unplugged and not hanging temporary. but the car will run richer and get worse gas mileage. if he has a bit of a drive, its not hard to mount them.
Reply #213
Quote from: jcassity;420621
question,,
#2
I now have GT40 heads with no pipe along the rear of the heads,, i guess this is internal EGR.  When running the motor, i see no EGR movement at all and would like to know if there is something i need to worry about or let it just sit there not moving and call it good.  with external EGR on the old heads, the egr moved ,,im sure now i am dumping an egr code,,, opinions?
Actually the EGR works the same as it did before. The intake you have is an internal EGR intake, just like the stock one. The GT40/GT40P heads all have the EGR passage just like every other stock head. The tubes running to the back of the heads are for the Thermactor system. They have nothing to do with the EGR. For instance on my Thunderbird (since it has no cats) I removed the smog pump, thermactor tubing, and the TAB and TAD solenoids without issue. I'm still running the EGR and was when I had GT40P heads on the car.
Reply #214
Jay 18MMX1.5 nuts welded in the pipes and you are dun. Ge out the miller a few sparks and a wif of OZONE and screw the O2 in the pipes and you are GOLDEN. Remember always mount them as vertical as possible. Never DOWN. Good luck on the car. OH YES PS hose not to bad to replace. Just jack up the engine and replace it. I am assuming it is the HI SIDE!!
Reply #215
Quote from: thunderjet302;420649
my EGR is not moving at all that i can see
Reply #216
Quote from: Haystack;420645
the o2 sensors are plugged in
they are not in the exhaust stream yet.  that will be my son's issue to solve.
i was asking what are the issues of having them plugged in but not in the exhaust stream
Reply #217
Quote from: TOM Renzo;420651
naw, i was just kidding, the power steering hoses are cake,, the high presure comes off easy as pie.. you just have to slide the rack/pinion bottie off to the side so you got more room.
its out now, will have new one tomorrow.
Reply #218
The ECM will institute a set voltage for limp in mode if the O2 sensore do not switch and light off. So the car will run fine not great untill they see some oxygen in the exhaust stream. Other than that installing them is MANDATORY. Why chance messing up a good rebuild with an fuel delivery mechanism not working properly. Get them in the exhaust system so you can close this project out. Good luck TOM!!
Reply #219
Ill see what i can do about that this week then.
i was talking with a service supervisor at the dealer, after he understood i was plugging them in but not having them in the exhaust stream,, he started to imply i may actually run a little lean but not that lean.
Reply #220
If memoy serves me it will un at or around 14. This is from memory. But for sure a new engine wont like that very much. Jay you know they make band clamps with those o2 fittings on them. No welding. just a big hole and a pair of 9/16 wrenches?????????????????
Reply #222
If you're going to leave them out of the exhaust stream, it's better to just unplug them.  This way, the PCM won't waste time trying to light them off, and won't waste fuel trying to alter the mix until they give a reading.  just unplug them and let it go to failsafe.  Tell Mason not to run it hard, as you don't want to risk over-leaning the engine because nothing is watching the mixture.  This isn't the way I'd want to run a fresh build.  Because seriously, a pair of tie-rod jam nuts do just fine as o2 ports.
Reply #223
earlier tom, did you mean,,,,,,,,,,,
mount the 02 perpendicular to the exhaust section its installed in?
Reply #224
Quote from: jcassity;420669
For reference see the picture on this page: http://www.summitracing.com/parts/sum-640725/overview/make/ford/model/mustang This is about where you should mount the O2 sensors. BTW I've had that particular H-pipe on my Thunderbird for years. It's a nice piece. It was only $110 when I bought it though.
