Topic: Jerky car (Read 4136 times) previous topic - next topic
Jerky car
I just wrapped my headers with a titanium header wrap and now when I drive my car jerks every 20-30 seconds and my air/fuel gauge drops into the red because it goes lean. Could the header wrap be cause some sort of prefire because of the extra heat inside the header? I also just put on new MSD spark plug wires which I had a hard time fitting onto the spark plugs.
Jerky car
the MSD wires could be the problem by them selves, the only wires that work correctly are the Motorcraft wires.
Jerky car
When my car did that, it was because of the ignition module on the distributor.
Jerky car
Did you break a wire on your O2 sensor(s)?
Does it do it at idle, wide open throttle, or just part throttle? If it only does it during normal, part throttle driving, I'd definitely check your O2 harnesses. O2's dont really function at idle or WOT, so that could help eliminate something before you throw parts at it or take it to a shop.
After that, if it's still unfound, codes. Vinnie's advice is spot on too, as is Graham's.
G'luck.
Jerky car
So It turned out to be my MSD coil. piece of  if you ask me. I throw on my spare basic one from autozone and it is back to running as smooth as chunky butter.
Thanks for the support guys!
Jerky car
WHEN WILL PEOPLE LEARN !!!! That a lot of aftermarket stuff is JUNK. Especially when it comes to electronic components and MSD products !!!
:hick::mullet:
Jerky car
Quote from: TOM Renzo;417611
:hick::mullet:
best cost vs best price,,,,
oddly enough MSD has figured out a way to break the rule and provide junk at a high price.
Jerky car
Quote from: vinnietbird;417597
you mean that bucking intermittantly you were having a few months back at low speeds with steady throttle applied?
Jerky car
Well said Jay that is exactly 100% correct. Think about how many miles and years a ford or for that matter any OEM electronic component lasts. Can't beat original stuff most of the time OE is superior or just as good.
Jerky car
It also might have been some py gas from fred meyers. I put in some fuel injector cleaner and im going to put in some chevron or shell gas after the tank gets low.
I am also having another problem. When I down shift and the RPMs are winding down around instead of going to lean like it use to, it runs really rich and back fires alot. I thought maybe a vacuum line but I cant find any leaks...
Jerky car
I had problems with my msd wires also,I could feel the loss of power,changed them back to the ford racing back to normal. go figure the msd's were twice the price
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Jerky car
Dang, I wish ford racing made wires for the 2.3
Jerky car
I'm glad his problem is solved but will someone explain why the afr was going lean if it was ignition related? I would've thought it would go rich and I'd be looking hopelessly for a problem elsewhere.
Jerky car
Quote from: SR71blackbird;417833
They do you just get 2 pairs. Lol
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Jerky car
So . . . with all these problems with MSD stuff, anyone have an opinion on the 6AL boxes?
