Topic: "Broken" orange wire..... (Read 4702 times) previous topic - next topic
In my harness that goes to the TAD solenoids behind the upper intake, at the "Y" of the harness, there's an orange wire there. It looks like it was either cut, or just never was used. What is it for?
year and trim then ill check on shopkey
'88 cougar 331 supercharged build in progress
'95 Blazer solid axle swapped 4X4- daily driver
1988 Thunderbird Sport. 5.0.
Oh, and I appreciate the help.
Looks to me like its a ground coming the ecu on pin #49 same with a gray and red stripe on pin #44
*ground to ecu
It's been like that since I've had it..I can add a wire to it and a ring on the end to ground it. I do wonder why I haven't noticed any bad stuff happening without the ground wire hooked up.
Yeah that is really weird lol might not control anything really important
That may explain it then.
yeah that might be it haha gotta love 87//88 parts interchange
I was thinking that bolted on the back of the head and was a ground for the HEGO.
Mike
Pin 49 is the isolated ground or better known as a CLEAN GROUND for the Oxygen Sensors. It belongs near the DIZZY so the O2 sensors have the same ground potential. I find it hard to believe your car runs correctly with this disconnected. Reason being if not connected it upsets the entire mixture the ECM sees. On the TC that wire goes to the TURBO BELL. If you want to do it correctly install 4 wire O2 sensors and run that wire to each of them. Other wise it belongs near the DIZZY. Just saying!!! Hope this helps!!
Or just ground it to the block somewhere. But the correct location is near the DIZZY.
Tom, every '88 Tbird and COugar I've seen has had this orange wire unfastened. There was a thread about it a year or so ago. People hook 'em up, there's no difference. Non issue, IMO.
OK i wont argue with you it is to early in the morning!! Every TC i have ever worked on has this wire connected to the TURBO BELL. What can i say??
Here is what FORD SAYS~~~  PIN 49  (HEGO GND) HEGO GROUND NEAR DISTRIBUTOR OR TURBO BELL.
