Topic: BlueBird (Read 103317 times) previous topic - next topic
Re: BlueBird
Reply #300
The Bird looks great. Should be a fun driver.
 S O L D
Re: BlueBird
Reply #301
Sounds like it's time to locate yo'self a Coyote and be a bigger dick. :rollin: :ford: :bowdown:
Re: BlueBird
Reply #302
I daily drive a 2018 Mustang GT. I don't really need another Coyote car.
Not to mention, those  swaps are expensive as hell.
Re: BlueBird
Reply #303
Maybe a year or two ago, Gumby and I were discussing builds and swaps that would be cool. I have access to a Mark VIII, so my "what if" build was to swap a DOHC 4.6L with a manual, and do the MM TA/PHB setup, 3 piece wheels and so on.
Pretty sure that conversation was considerably longer than a couple years ago. I recall telling you to go for it, as I wanted nothing to do with a modular swap at that point, and I was still enamored with the IRS. Definitely already had these wheels at least....Funny how things change.
I am calling this mock-up complete. There was some clearancing necessary to the seat bracing under the floor pan, and a bit of tender massaging to the tunnel/floorpan area. Looking pretty good from my vantage. Next up, I need to grab a couple feet of 2x2x0.125" angle to construct brackets for the T/A crossmember, and then paint all this bare steel under the car.
Re: BlueBird
Reply #304
How much ground clearance are you going to have for that torque arm? Looks pretty low.
Re: BlueBird
Reply #305
Since it is fixed to the axle, ground clearance is directly determined by tire size.  :dunno:
Re: BlueBird
Reply #306
Yeah, so pretty low.
Looks good. Should be fun!
Re: BlueBird
Reply #307
Have over 10,000 miles on my Coupe with the MM TA and zero issues. Running 275/40R17 Nitto 555R’s in the rear now and used to run 245/40R17 Dunlop Dirreza’s on the past.  The clearance Issue I have is the stock air dam with the car so low.
Killer project man!!!
Re: BlueBird
Reply #308
Looks awesome.
Still using the stock steel driveshaft I see.
Re: BlueBird
Reply #309
It is actually a TC shaft(larger u-joints) with a 31T slip yoke. The aluminum Mustang one I have here is a touch too short still.
Re: BlueBird
Reply #310
Bonus content! My son had a doc appt this morning which took longer than expected and I decided it wasn't worth driving into work afterwards. I will be a much higher functioning human tomorrow after a mental health day, so I locked myself in the garage, cranked up the stereo, and ignored the outside world.
T/A cross member brackets. Before, and after some metallic origami. After, pictured with gusseted doublers, ready to be assembled.
And welded, ready for installation
Re: BlueBird
Reply #311
Man, I love when I get those rare days.
Those brackets look good. Great execution.!
Can you make a swan next?  :toothless:
Re: BlueBird
Reply #312
I would like to utilize your services please.
Re: BlueBird
Reply #313
Those brackets are really nice. Sweet.
Re: BlueBird
Reply #314
Baby step
