Topic: BlueBird (Read 103696 times) previous topic - next topic
BlueBird
Quote from: gumby;467492
I thought I was only supposed to grab 2 sets if they were sn95 and needed modded, my fault. :toilet:
It's all good. I'm probably going to use a fox booster to simplify things anyways.
BlueBird
Was the engine plan for this still what we discussed? I couldn't remember if that was for this car, white car, or something else.
BlueBird
Yup, still accurate at this time. I have decided to keep this a running and driving project as much as possible. I roughed out multiple stages that should facilitate big upgrades in the winter and smaller tweaks during the driving seasons. Stages are somewhat modular and timeline will depend on several factors; I just need to stick to the plan and do work!
BlueBird
Duratec!
BlueBird
I spent a bunch of time today organizing and cleaning my shop. There were piles of Fiat parts all over the floor which needed moved to my parts dept. and Tbird parts that needed moved in. Having only finished the inside of my building last winter and being busy all summer, I still lack shelving, benches, and cabinets that make a shop function well. I knocked together another set of shelves, raided my parts stash, and got all this moved in and put away.
X
BlueBird
Are those that sick-ass set of wheels you had on your TC?
BlueBird
Quote from: ThunderbirdSport302;467563
One and the same. They are gonna look bitchin on this blue :evilgrin:
BlueBird
Are you going to change out the stock rear control arms while you're swapping the rear axle?
BlueBird
Quote from: thunderjet302;467572
No. The main goal for this round of suspension work is to get the car back on the road and somewhat presentable. The right front brake caliper is locked up and I refused to replace it with another Fox caliper when I knew I wanted 5lugs to hang my wheels on. Similar situation with rear arms; I know they will get upgraded down the road and I do not want to be double purchasing a bunch of parts. When I get into the major suspension redo, I will handle control arms at all corners.
5lugs, springs, and bars for now. I will probably toss the 15:1 steering rack on while everything is apart and regear the sn95 7.5 because I have all the stuff here to do so.
BlueBird
Reply #39
Ah. Makes sense. I thought you were swapping in a 8.8 at this point. Are you eventually going IRS? I thought your white car had the IRS setup out of a 03-04 Cobra.
BlueBird
Reply #40
Quote from: thunderjet302;467580
No IRS this time. I decided my modded IRS was overkill for the intended do-all street car purpose.
It will resurface under a Coyote/6spd Zephyr project I am consulting on.
BlueBird
Reply #41
Louis is now disappointed that he couldn't suggest you buy Maximum Motorsports control arms.
BlueBird
Reply #42
Quote from: Tbird232ci;467602
Was actually going to suggest a Maximum Motorsports panhard bar, because I want someone to buy one and install it before I buy one. That way if it doesn't fit well I'm not out the money :hick:.
BlueBird
Reply #43
Quote from: gumby;467583
Got pictures of that project? It sounds cool.
BlueBird
Reply #44
Quote from: thunderjet302;467606
There was someone on another facebook group that had one installed. I can't remember who. Probably the group I got banned from.
Knowing gumby, he will probably make something anyways.
