Topic: BlueBird (Read 104931 times) previous topic - next topic
Re: BlueBird
Reply #255
NiCopp. Amazing stuff!
Re: BlueBird
Reply #256
I thought it looked like it. Gonna need some of that for the 240 project, most likely.
Re: BlueBird
Reply #257
Not sure it will be an issue, but knowing how close my right header is to the rail I would be concerned about cooking the fluid in the line there. Just a thought.
Re: BlueBird
Reply #258
That was my reasoning for pulling the line to the outside of the rail and bringing it back inside further forward. There is enough air gap at the new location that I am not concerned.
Re: BlueBird
Reply #259
Brake lines promised and delivered
Re: BlueBird
Reply #260
Looks awesome!
Re: BlueBird
Reply #262
Tees dotted and eyes crossed, hopefully the last time I install this drivetrain for a while
Re: BlueBird
Reply #263
That fits under the stock hood correct?
Re: BlueBird
Reply #264
Working on wiring. No good for pics, so here is a RADwood flavored teaser
Re: BlueBird
Reply #265
Yeah, that's definitely RADwood material.
Re: BlueBird
Reply #266
Needs more neon pink.
Re: BlueBird
Reply #267
Adding details so that after this is done I can read back thru and adjust my selective memories. I spent an hour last night moving the washer tank forward 3/4" to clear the sn95 underhood power distribution box, and forgot to take a pic cause it looks stock...
Re: BlueBird
Reply #268
Moderate wire tuck
And  if there isn't a lot going on in this left front corner....
Re: BlueBird
Reply #269
Looks pretty clean.
Things are pretty tight under the hood, though, so it's probably best.
