Topic: BlueBird (Read 82567 times) previous topic - next topic
Re: BlueBird
Reply #120
Pool balls tend to crack when drilled......
Don't ask how I know :-0
Re: BlueBird
Reply #121
While the seat is out for the pedal swap, I needed to address the infamous lean
A bunch of popped spot welds and one crack in the pan.
Re: BlueBird
Reply #122
Job 1, Gumby.
Job 1.
 :toothless:
Re: BlueBird
Reply #123
I have been mildly sidetracked messing with some new to me shop equipment. I brought home a 48x48 welding table, and a 60gal air compressor. I did the welding of the seat back frame on the new table. I reassembled and installed the seat only to discover that the pedals I had put in were too close together. My foot would catch the brake pedal when actuating the clutch. PO of these pedals swapped an auto brake pedal in. I didn't catch that! I cut off the left edge of the auto pedal and installed the clutch pad on the brake pedal. I will grab another clutch pedal pad soon, but for now I trimmed the brake pedal pad to fit the clutch pedal and my feet fit as intended.
I got to put the new air compressor to work today when I found out that register hole in my stock block plate was too small for the F150 PMGR starter! This frustrated me a bit because it was the only thing I didn't test fit on the bench, and I am not sure why I overlooked it. But all is well that ends well I suppose, some work with a drum sander on an angle grinder was enough to open the hole up allowing the starter to sit flush on the block plate. I turned attention to the wiring changes required for the PMGR starter, got that done and began looking for reasons not to start the car. Mental checklist of possible negative consequences eliminated, I hooked up the battery. No smoke.... Hopped in the driver's seat, pushed in the clutch, turned the key to see the dash light up and listen to the fuel pump, then hit the start circuit.....nothing  :nonchalance:  D'oh, this car doesn't know the clutch is depressed! Hop back out, disconnect the battery again, grab the pigtail off the AOD and wire up a NSS loop.
Perma-neutral engaged, I climbed in for a second attempt. I was rewarded with LOUD noises. No unexpected noises at least, but open manifolds, sheesh. Trans goes into gear with the engine running, clutch works, and the car will move both forward and rearward under its own power. :roxor:
May 18th is not as far away as I would like to think it is, so it is time for a punch list to make that deadline.
In no particular order:
  • Fill trans
  • Check rear gear oil
  • Engine oil change
  • Seal shifter
  • Reassemble center stack and console trim
  • Rebleed brakes
  • Tighten all suspension components
  • Alignment
  • Paint trim on TC bumper cover
  • Convert red stripes to chrome for all nose trim
  • Reassemble nose
  • Mach1 air dam
  • Check wheels for leaks and reseal as needed
  • Wire up cooling fan
  • Install TC sway bars
  • Finish exhaust
  • Fog lights?
  • Reverse lights
  • Speedo gear
There is plenty more to come, but that should get stg1 completed before the May 18th get together in Owensboro. I reserve the right to rearrange or add to my punch list as necessary.
Re: BlueBird
Reply #124
Sa-Weet!
 :headbang:
Re: BlueBird
Reply #125
Got to love it when they move under there own power, but forward and rearward, now that's just showing off.
Re: BlueBird
Reply #126
Awesome! You're almost there.
Re: BlueBird
Reply #127
  • Fill trans
  • Engine oil change
  • Seal shifter
  • Rebleed brakes
  • Alignment
  • Reassemble nose
  • Mach1 air dam
  • Finish exhaust
  • Fog lights?
  • Reverse lights ✔️
  • Speedo gear ✔️
Re: BlueBird
Reply #128
Awesome!
Re: BlueBird
Reply #129
Steps 1&2:
Step 67:
Step 369:
Step 12478:
Then welded all that I could reach with the y-pipe attached to the car. Next up: finish weld, add a couple hangers, and connect to the old ler.
Re: BlueBird
Reply #130
Nice work!
Re: BlueBird
Reply #131
Steps 1&2:
Step 67:
Step 369:
Step 12478:
It looks great.
I can't imagine why you wouldn't want to drive around with an open header/manifold 3.8  :toothless: .
Re: BlueBird
Reply #132
Sure would like to see the photos for steps 370 thru 12477.   I built my exhaust from bends and know exactly where you are coming from. Looking good.
Re: BlueBird
Reply #133
I should have done a time lapse! That would show how many times I walked between the car, chop saw, welding table, and grinder  :rollin:
Re: BlueBird
Reply #134
  • Fill trans
  • Engine oil change
  • Seal shifter
  • Rebleed brakes
  • Alignment
  • Reassemble nose
  • Mach1 air dam
  • Finish exhaust✔️
  • Fog lights?
  • Reverse lights ✔️
  • Speedo gear ✔️
Silence is golden
