Topic: Busted bolts!!! (Read 2483 times) previous topic - next topic
Busted bolts!!!
Quote from: 88CabernetKitty;415714
Well, unless it's a coastal car that's been run on the beach. That salt and sand combo can sometimes be much worse on a car than northern road salt.
Imagine how bad we have it here - road salt AND sea salt. I've seen frames rusted through on Chevy trucks as new as 2008 (and this was also an issue on 1997-2003 Ford trucks, but they seem to have gotten better since 2004), and rear subframes on Dodge Calibers rotted beyond repair.
Another method I use to remove broken bolts is grind a slot into the broken bolt and turn it out with a screwdriver, but this only works on bolts that broke due to overtightening or from stress (such as Ford and Dodge manifold bolts)
Busted bolts!!!
i guess thats whats kinda neat about living in the rot belt, while it sucks when you run into these situations. sometimes a smoke, a break and having at it can be kinda "fun".
