Topic: T-5 problem..... (Read 4172 times) previous topic - next topic
T-5 problem.....
Darren, if you can get it, I'll have funds as soon as the GT-40 upper is sold. I appreciate your time and help.
T-5 problem.....
Darren, PM sent.
T-5 problem.....
I MAY have a deal on a T-5 here tomorrow. Came from my good friend's '67 Mustang (he did the conversion), and he pulled it to install an AOD-E and paddle shifter set up. $100. I can't beat that with a stick. news as it happens.
T-5 problem.....
Thats a bargain and GOOD LUCK
T-5 problem.....
Thanks a lot.
T-5 problem.....
Well the guy that was selling the T-5 down here called me and mentioned that it came out of a 2001 Camero.  I passed on it as I am not sure it would be a direct bolt in even though he said he "thought" it was.  I'll keep looking.
Darren
T-5 problem.....
the Camero uses a different style pick up and different spine input shaft. I'm sure it could be made to work. one problem though, some year cameros have different offset bellhousings to angle the.shifted in the trans tunnel.
T-5 problem.....
I did some research and the main box would work.  Different shifter location, different bell housing, different input shaft...so basically different.  If I had a T-5 with blown gears then I would get it and just morph the two together and have one good T-5 for a Fox but that is kind of ridiculous unless I could get it for near nothing.
I am hoping Vinnie can get the one he has located for $100 because if it is working its a steal.
Darren
T-5 problem.....
sn-95's go for.cheap all the time. I passed on one for .$150 a couple months ago.
T-5 problem.....
If there was one near me, I'd grab it and the bell housing asap. I have a friend local to me who has a T-5 for me. I'm waiting on him to call me to come pick it up. I'll have it this evening or tomorrow. I got a wicked good deal on it, so I'll have more news on it when I get it. Stay tuned.
T-5 problem.....
Quote from: Aerocoupe;414808
Mine started popping out of first gear due to bad synchros.  Took it to a buddy to rebuild and bought the Hanlon Motorsports complete rebuild kit.  Ended up replacing one gear and adding the G-Force counter gear stabilizer as well but that was over five years ago.  I just had him check it all out a few months back prior to the 331 going in the car and he only added a couple of thousandths of shim to the input shaft.  Building one ensures you get a good transmission versus buying a used one you know nothing about.  There are a few guys up in the OKC area that build these trannys for a bill plus parts so it may be worth it to have one of them check it out.
http://www.hanlonmotorsports.com/?q=node/3
http://www.5speeds.com/t5.htm
I would wait to order the rebuild kit until it is torn down and you know what if anything is wrong.  There is a really good master rebuild kit on ebay with Koyo bearings here:
If it was me and this was the kit I needed I would call them and get the premium kit with the Timken bearings but that is totally my personal preference.  Anyhow, hopefully its something simple and it won't need a rebuild.
Darren
I really like that counter gear stabilizer.
T-5 problem.....
Yeah, I really did not know what my buddy was talking about when he asked me to get it but he said it was a must for these transmissions.  I figure if I need the T-5 to hold more power I will just get a TKO 500 as it will hold about 500 ft-lb of torque and has a ten spline input shaft to no clutch change.  From what I have read you have to change the bell housing and the exhaust hangers have to be modified a little bit but no much is a direct plug and play anymore.
Darren
